Two Coding Problems
Sun Shine pengsens at hotmail.com
Thu Jan 12 07:33:13 UTC 2006
>Hi Sun Shine,
>In answer to your second question, I would say it is because your
>init task is running off the end of the task and so the init task is
>deleted.  Then by the time your second task gets to run, it will
>find the first available ID and use it, and this would have been the
>one that the Init task was using.
>To stop this effect, at the end of your init task, put an endless
>loop, such as:
>while(1)
>    rtems_task_wake_after(100);
>or you could just suspend the task instead of deleting it (by
>running off the end, such as:
>    rtems_task_suspend(0);
>I hope this helps.
>regards,
>Ian Caddy
I don't think this can handle the problem.
Use my code again, for example , T0 create T1 and T2,and T1 create T3 , T2
create T4
then the IDs are:
   T0: a010001 (Init Task)
   T1: a010002 (Created by T0)
   T2: a010003 (Created by T0)
   T3: a010004 (Created by T1)
   T4: a010001 (Created by T2)
If just like you said , the ID of T3 should be a010001 and the ID of T4
should be a010002, because T1 and T2 are non-existent.
And I also tried your method: use rtems_task_suspend(0) instead of
rtems_task_delete(0), in Init(), the result is:
   T0: a010001
   T1: a010002
   T2: a010003
   T3: a010004
   T4: a010002
Then I use rtems_task_suspend(0) to replace rtems_task_delete(0) in all the
methods --- Init(),get_task_info() and create_task(),there comes the
problem: T4's creation will fail.
_________________________________________________________________
与联机的朋友进行交流,请使用 MSN Messenger:  http://messenger.msn.com/cn
