failure notice
Mark Vander Voord
mvandervoord at gmail.com
Fri Jan 20 00:34:13 UTC 2006
Does using the Rate Monotonic Scheduler override the standard
priority-based scheduling in some way?
In my init function, I am launching a task which has been configured
to run using an RMS period. I have the following RTEMS options
defined (among other, unrelated options):
#define CONFIGURE_INIT_TASK_PRIORITY
1
#define CONFIGURE_INIT_TASK_ATTRIBUTES
RTEMS_FLOATING_POINT | RTEMS_LOCAL
#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_NO_PREEMPT
| RTEMS_NO_TIMESLICE
With these settings, I believe that the INIT task would be
un-interruptable by any other task until it have finished or parked.
However, this is not the case. As soon as I have created the task
mentioned above (which has a priority of 25 and a rate of 5msec), that
task is immediately run. It continues to run every 5msec from then
on, taking priority over the INIT task.
Are there other settings that I am missing to get the behavior that I
desire, or do I need to delay creation of the RMS period?
Mark S VanderVoord
