help for first installation of rtems
Ralf Corsepius ralf.corsepius at rtems.org
Sun Jan 22 08:19:29 UTC 2006
On Sun, 2006-01-22 at 02:19 -0500, Paul Evans wrote:
> Hi,
> I seem to recall hearing that later versions of gcc behave differently when
> assigning to lvalues that require evaluation (A C99 compliance issue).
Yep.
>  What
> version of gcc are you using? Is it the same as the one 4.6.5 was validated
> on?
> Just a thought..
You are very probably right on the spot. The RTEMS code base Matteo
seems to be too old for the GCC he is using.
Ralf
