PSIM and MP tests -- anybody got working?
Karel Gardas kgardas at objectsecurity.com
Mon Jan 23 15:36:36 UTC 2006
On Mon, 23 Jan 2006, Joel Sherrill wrote:
>> Also if you do have any documentation reference how to even start those
>> test, that might also be helpfull. So far I've just patched gdb,
>> uncommented sem/shm related lines in psim script and try to start one psim
>> with *node1 test and then the second with *node2 test...
> The script runtest in psim/tools has the procedure as of the last time it
> worked.
Thanks for this note, I see you use 1 and -1 for sem initialization which
looks like it should run. I will test on head during the night.
Thanks,
Karel
ObjectSecurity Ltd.           http://www.objectsecurity.com
