PSIM and MP tests -- anybody got working?
Mon Jan 23 22:53:06 UTC 2006
Karel Gardas wrote:
> On Mon, 23 Jan 2006, Joel Sherrill wrote:
>>>> runtest seems to be able to drive powerpc-rtems-run but I'm not having
>>>> any luck with getting a device tree file that gdb likes.  Any luck
>>>> on your
>>>> side?
>>> Yes, my MP tests seems to run -- at least few of them, many of them
>>> complains about caught signal -1 -- I assume those just consumed all
>>> the "preallocated" instructions, right?
>> Possibly but it may not be.  Does it hang for a while and then die?
> Yes.
>>> BTW: Which gdb do you use?
>> I went back to the old 4.6 gdb which I thought had a working sem/shm
>> driver in it.
>> mp01 has limited communication between the two nodes so there isn't
>> any failure
>> if they don't communicate. mp02 really has the tasks interacting in a
>> simple way. I need to be able to gdb and see what is up.
> Aha, thanks for the info! BTW: Here also tests 10 and 11 seems to run
> well.
I don't remember what they do.
Which gdb are you using?  If it is a 6.x, I would prefer to switch.  I
can't seem to get the device tree to work with gdb.
> Cheers,
> Karel
> Karel Gardas                  kgardas at objectsecurity.com
> ObjectSecurity Ltd.           http://www.objectsecurity.com
