[PATCH] how to fix shmdr for POLLING? [was: Re: PSIM and MP tests -- anybody got working?]
Karel Gardas kgardas at objectsecurity.com
Mon Jan 23 23:04:48 UTC 2006
On Mon, 23 Jan 2006, Joel Sherrill wrote:
> I was afraid of this.  shmdr has not been used with new execption model
> and assumes it can "wrap" the clock tick driver ISR.  It was written before
> the Timer Manager exists.  Instead of its clock tick ISR trick, it should
> install
> an RTEMS timer to run once a tick when polled.
If I understand this well, then the code should looks like in diff below,
but the problem is that then Shm_Poll seems to be run too often (just my
idea), since I usually end with consumed amount of instructions/time...
Even if I go with 1000 clicks, it's still the same, but test at least runs
some functionality. I guess my task setup is wrong...
Do you have any idea how to fix this?
Thanks,
Karel
ObjectSecurity Ltd.           http://www.objectsecurity.com
Index: Makefile.am
RCS file: /usr1/CVS/rtems/c/src/libchip/Makefile.am,v
retrieving revision 1.36
diff -u -r1.36 Makefile.am
--- Makefile.am	12 Jan 2006 10:12:31 -0000	1.36
+++ Makefile.am	23 Jan 2006 22:59:35 -0000
@@ -96,7 +96,7 @@
  shmdr_rel_SOURCES = shmdr/addlq.c shmdr/cnvpkt.c shmdr/getlq.c shmdr/dump.c \
      shmdr/fatal.c shmdr/getpkt.c shmdr/init.c shmdr/initlq.c shmdr/intr.c \
      shmdr/mpisr.c shmdr/poll.c shmdr/receive.c shmdr/retpkt.c shmdr/send.c \
-    shmdr/setckvec.c
+    shmdr/poller.c
  shmdr_rel_CPPFLAGS = $(AM_CPPFLAGS)
  shmdr_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
  endif
Index: shmdr/init.c
RCS file: /usr1/CVS/rtems/c/src/libchip/shmdr/init.c,v
retrieving revision 1.16
diff -u -r1.16 init.c
--- shmdr/init.c	20 Apr 2004 10:43:39 -0000	1.16
+++ shmdr/init.c	23 Jan 2006 22:59:36 -0000
@@ -20,6 +20,7 @@
  #define _SHM_INIT
+#include <rtems/rtems/tasks.h>
  #include <shm_driver.h>
  #include <string.h>    /* memset() */
@@ -126,8 +127,21 @@
    interrupt_value   = Shm_Convert( Shm_Configuration->Intr.value );
    interrupt_cause   = Shm_Convert( Shm_Configuration->Intr.length );
-  if ( Shm_Configuration->poll_intr == POLLED_MODE ) Shm_setclockvec();
-  else                                               Shm_setvec();
+  if ( Shm_Configuration->poll_intr == POLLED_MODE ) {
+    rtems_name task_name;
+    rtems_id tid;
+    rtems_status_code status;
+    task_name = rtems_build_name( 'P', 'S', 'H', 'M' );
+    status = rtems_task_create( task_name,
+                                1,
+                                RTEMS_MINIMUM_STACK_SIZE,
+                                RTEMS_NO_TIMESLICE | RTEMS_NO_ASR | RTEMS_INTERRUPT_LEVEL(0),
+                                RTEMS_NO_FLOATING_POINT | RTEMS_LOCAL,
+                                &tid );
+    status = rtems_task_start( tid, Shm_Poller_task, 0 );
+  else Shm_setvec();
    if ( Shm_Is_master_node() ) {
Index: shmdr/poll.c
RCS file: /usr1/CVS/rtems/c/src/libchip/shmdr/poll.c,v
retrieving revision 1.15
diff -u -r1.15 poll.c
--- shmdr/poll.c	20 Apr 2004 10:43:39 -0000	1.15
+++ shmdr/poll.c	23 Jan 2006 22:59:36 -0000
@@ -27,12 +27,6 @@
  void Shm_Poll()
    uint32_t   tmpfront;
-  rtems_libio_ioctl_args_t args;
-  /* invoke clock isr */
-  args.iop = 0;
-  args.command = rtems_build_name('I', 'S', 'R', ' ');
-  (void) rtems_io_control(rtems_clock_major, rtems_clock_minor, &args);
     * Check for msgs only if we are "up"
Index: shmdr/shm_driver.h
RCS file: /usr1/CVS/rtems/c/src/libchip/shmdr/shm_driver.h,v
retrieving revision 1.25
diff -u -r1.25 shm_driver.h
--- shmdr/shm_driver.h	29 Sep 2004 20:36:20 -0000	1.25
+++ shmdr/shm_driver.h	23 Jan 2006 22:59:38 -0000
@@ -479,8 +479,9 @@
  void           Shm_Print_statistics( void );
  void           MPCI_Fatal( Internal_errors_Source, boolean, uint32_t);
  rtems_task     Shm_Cause_interrupt( uint32_t);
+rtems_task     Shm_Poller_task( rtems_task_argument unused );
  void           Shm_Poll();
-void           Shm_setclockvec();
+/* void           Shm_setclockvec(); */
  void           Shm_Convert_packet( rtems_packet_prefix * );
  /* CPU specific routines are inlined in shmcpu.h */
--- /dev/null	2005-04-30 23:10:27.000000000 +0200
+++ shmdr/poller.c	2006-01-23 23:49:08.000000000 +0100
@@ -0,0 +1,33 @@
+/*  Shm_Poller_task
+ *  This routine serves as a Shm_Poller task. It just calls Shm_Poll
+ *  every tick.
+ *  Input parameters:  NONE
+ *  Output parameters:  NONE
+ *  COPYRIGHT (c) 1989-1999.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+ *  $Id: $
+#include <rtems.h>
+#include <rtems/libio.h>
+#include "shm_driver.h"
+  rtems_task_argument unused
+  for ( ; ; ) {
+    rtems_task_wake_after( 1 );
+    Shm_Poll();
