gcc4.0.2/newlib1.14.0 build failure for i386-rtems target
Karel Gardas kgardas at objectsecurity.com
Sat Jan 28 12:51:41 UTC 2006
Sorry for noise, this was caused by me linking newlib to the gcc's build
directory instead to source directory.
Cheers,
Karel
On Sat, 28 Jan 2006, Karel Gardas wrote:
> Hello,
> I've found on ftp.rtems.com tarbals of gcc-4.0.2 and newlib-1.14.0 and though
> that this is most uptodate recommended toolchain for RTEMS CVS head. The
> problem is that while building it for i386-rtems target it fails with:
> /tmp/i386-rtems/obj-gcc/gcc/xgcc -B/tmp/i386-rtems/obj-gcc/gcc/
> -B/home/karel/usr/local/i386-rtems-toolchain//i386-rtems/bin/
> -B/home/karel/usr/local/i386-rtems-toolchain//i386-rtems/lib/ -isystem
> /home/karel/usr/local/i386-rtems-toolchain//i386-rtems/include -isystem
> /home/karel/usr/local/i386-rtems-toolchain//i386-rtems/sys-include -O2
> -I../../gcc-4.0.2/gcc/../newlib/libc/sys/rtems/include -DIN_GCC
> -DCROSS_COMPILE   -W -Wall -Wwrite-strings -Wstrict-prototypes
> -Wmissing-prototypes -Wold-style-definition  -isystem ./include   -g
> -DHAVE_GTHR_DEFAULT -DIN_LIBGCC2 -D__GCC_FLOAT_NOT_NEEDED -Dinhibit_libc -I.
> -I. -I../../gcc-4.0.2/gcc -I../../gcc-4.0.2/gcc/.
> -I../../gcc-4.0.2/gcc/../include -I../../gcc-4.0.2/gcc/../libcpp/include
> -DL_fixunsdfsi -c ../../gcc-4.0.2/gcc/libgcc2.c -o libgcc/./_fixunsdfsi.o
> In file included from /tmp/i386-rtems/obj-gcc/gcc/include/syslimits.h:7,
>                 from /tmp/i386-rtems/obj-gcc/gcc/include/limits.h:11,
>                 from ../../gcc-4.0.2/gcc/libgcc2.c:1487:
> /tmp/i386-rtems/obj-gcc/gcc/include/limits.h:122:61: error: no include path
> in which to search for limits.h
> make[2]: *** [libgcc/./_fixunsdfsi.o] Error 1
> make[2]: Leaving directory `/tmp/i386-rtems/obj-gcc/gcc'
> make[1]: *** [stmp-multilib] Error 2
> make[1]: Leaving directory `/tmp/i386-rtems/obj-gcc/gcc'
> make: *** [all-gcc] Error 2
> Is this known failure?
> Thanks,
> Karel
> ObjectSecurity Ltd.           http://www.objectsecurity.com
