gcc4.0.2/newlib1.14.0 build failure for i386-rtems target
Brian Rose lists at brianrose.net
Sat Jan 28 14:26:32 UTC 2006
So have you successfully used gcc-4.0.2 to build rtems? I tried several
months ago and found that rtems would not build because the rtems code
contains some macros and other constructs that are considered errors in the
newer compiler.
Thanks,
Brian
Karel Gardas wrote:
> Sorry for noise, this was caused by me linking newlib to the gcc's build
> directory instead to source directory.
> Cheers,
> Karel
> On Sat, 28 Jan 2006, Karel Gardas wrote:
>> Hello,
>> I've found on ftp.rtems.com tarbals of gcc-4.0.2 and newlib-1.14.0 and
>> though that this is most uptodate recommended toolchain for RTEMS CVS
>> head. The problem is that while building it for i386-rtems target it
>> fails with:
>> /tmp/i386-rtems/obj-gcc/gcc/xgcc -B/tmp/i386-rtems/obj-gcc/gcc/
>> -B/home/karel/usr/local/i386-rtems-toolchain//i386-rtems/bin/
>> -B/home/karel/usr/local/i386-rtems-toolchain//i386-rtems/lib/ -isystem
>> /home/karel/usr/local/i386-rtems-toolchain//i386-rtems/include
>> -isystem
>> /home/karel/usr/local/i386-rtems-toolchain//i386-rtems/sys-include -O2
>> -I../../gcc-4.0.2/gcc/../newlib/libc/sys/rtems/include -DIN_GCC
>> -DCROSS_COMPILE   -W -Wall -Wwrite-strings -Wstrict-prototypes
>> -Wmissing-prototypes -Wold-style-definition  -isystem ./include   -g
>> -DHAVE_GTHR_DEFAULT -DIN_LIBGCC2 -D__GCC_FLOAT_NOT_NEEDED
>> -Dinhibit_libc -I. -I. -I../../gcc-4.0.2/gcc -I../../gcc-4.0.2/gcc/.
>> -I../../gcc-4.0.2/gcc/../include
>> -I../../gcc-4.0.2/gcc/../libcpp/include -DL_fixunsdfsi -c
>> ../../gcc-4.0.2/gcc/libgcc2.c -o libgcc/./_fixunsdfsi.o
>> In file included from /tmp/i386-rtems/obj-gcc/gcc/include/syslimits.h:7,
>>                 from /tmp/i386-rtems/obj-gcc/gcc/include/limits.h:11,
>>                 from ../../gcc-4.0.2/gcc/libgcc2.c:1487:
>> /tmp/i386-rtems/obj-gcc/gcc/include/limits.h:122:61: error: no include
>> path in which to search for limits.h
>> make[2]: *** [libgcc/./_fixunsdfsi.o] Error 1
>> make[2]: Leaving directory `/tmp/i386-rtems/obj-gcc/gcc'
>> make[1]: *** [stmp-multilib] Error 2
>> make[1]: Leaving directory `/tmp/i386-rtems/obj-gcc/gcc'
>> make: *** [all-gcc] Error 2
>> Is this known failure?
>> Thanks,
>> Karel
>> Karel Gardas                  kgardas at objectsecurity.com
>> ObjectSecurity Ltd.           http://www.objectsecurity.com
