gcc4.0.2/newlib1.14.0 build failure for i386-rtems target
Ralf Corsepius ralf.corsepius at rtems.org
Sat Jan 28 14:54:39 UTC 2006
On Sat, 2006-01-28 at 09:26 -0500, Brian Rose wrote:
> So have you successfully used gcc-4.0.2 to build rtems? I tried several
> months ago and found that rtems would not build because the rtems code
> contains some macros and other constructs that are considered errors in the
> newer compiler.
You'd need rtems-CVS.
rtems-4.6.x is neither ready for gcc-4.x nor for newlib-1.14.x
Fedora users might be interested in the srpms these FE package requests
point to:
https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=176697
https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=176712
They contain my latest sources and patches.
Ralf
