problem to install rtems
Matteo
matteo.posterli at studenti.unipr.it
Sun Jan 29 18:58:47 UTC 2006
Hi
I have install gcc-2.16.1, binutils-2.16.1 and newlib-1.13.0 with the patch
newlib-1.13.0-rtems-20050810.diff and binutils-2.16.1-rtems-20050816.diff.
I have configured rtems with;
/usr/local/rtems/source/b-rtems# ../rtems-4.7/configure --target=i386-rtems4.7
--prefix=/usr/local/rtems/rtems4.7 --enable-cxx --enable-rdbg --disable-tests
--enable-networking --enable-posix --enable-rtemsbsp=pc386
and all ok, after I try to do ;
root at matteo:/usr/local/rtems/source/b-rtems# make all
and I have an error like the following;
i386-rtems4.7-gcc --pipe -DHAVE_CONFIG_H -isystem
../../../../pc386/lib/include -D__RTEMS_INSIDE__ -O4 -g -Wall -ansi -fasm
-o o-optimize/event.o -c
../../../../../../rtems-4.7/c/src/../../cpukit/rtems/src/event.c
-o o-optimize/eventreceive.o -c
../../../../../../rtems-4.7/c/src/../../cpukit/rtems/src/eventreceive.c
-o o-optimize/eventseize.o -c
../../../../../../rtems-4.7/c/src/../../cpukit/rtems/src/eventseize.c
-o o-optimize/eventsend.o -c
../../../../../../rtems-4.7/c/src/../../cpukit/rtems/src/eventsend.c
-o o-optimize/eventsurrender.o -c
../../../../../../rtems-4.7/c/src/../../cpukit/rtems/src/eventsurrender.c
../../../../../../rtems-4.7/c/src/../../cpukit/rtems/src/eventsurrender.c: In
function '_Event_Surrender':
../../../../../../rtems-4.7/c/src/../../cpukit/rtems/src/eventsurrender.c:67:
error: invalid lvalue in assignment
../../../../../../rtems-4.7/c/src/../../cpukit/rtems/src/eventsurrender.c:99:
make[4]: *** [o-optimize/eventsurrender.o] Error 1
make[4]: Leaving directory
`/usr/local/rtems/source/b-rtems/i386-rtems4.7/c/pc386/exec/rtems'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory
`/usr/local/rtems/source/b-rtems/i386-rtems4.7/c/pc386/exec'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/usr/local/rtems/source/b-rtems/i386-rtems4.7/c/pc386'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/local/rtems/source/b-rtems/i386-rtems4.7/c'
make: *** [all-recursive] Error 1
I don't know why I have this problem, someone can help me ?
thanks in advance
Matteo Posterli
