[pc386 BSP] ticker.exe issue (CVS head)
Mon Jan 30 15:24:33 UTC 2006
Karel Gardas wrote:
> Hello,
> I was not able to find out which toolchain combination I used in
> August 2005, nor which exact version of RTEMS I used that days. I've
> tried to get back in CVS history, but also w/o success.
> Anyway, I tried to debug this issue, and I started with hacking
> ticker.exe test. I've added some printfs and/or a bit waiting before
> creating next task and now I see at least TA3 is running as expected.
> The issue is while others are not running/ticking?
> See patch below. If you uncomment added printfs, TA3 should run well.
> If I keep it as it is, tasks are just started and after short period
> of time I get a lot of messages to the console -- I cannot read them,
> since it scrolls too fast and its VGA. I've tried the same in Qemu and
> got:
> silence:/images$ ~/usr/local/qemu-2005-12-18/bin/qemu -fda
> /images/grub-boot.flp
I get the same thing with my RPMs but when I use my gcc tools from the
head,
ticker runs.  They were built January 24.
Also FWIW I am using a serial port as a console on qemu.
Looking at the address, my first guess would be a blown stack
somewhere.
> Trying to execute code outside RAM or ROM at 0xef57f000
> EAX=ef57f000 EBX=0000000a ECX=001275a0 EDX=00000001
> ESI=0012d130 EDI=00000000 EBP=0012c624 ESP=0012c5f8
> EIP=ef57f000 EFL=00003002 [-------] CPL=0 II=0 A20=1 HLT=0
> ES =0010 00000000 ffffffff 00cf9300
> CS =0008 00000000 ffffffff 00cf9e00
> SS =0010 00000000 ffffffff 00cf9300
> DS =0010 00000000 ffffffff 00cf9300
> FS =0010 00000000 ffffffff 00cf9300
> GS =0010 00000000 ffffffff 00cf9300
> LDT=0000 00000000 0000ffff 00008000
> TR =0000 00000000 0000ffff 00008000
> GDT=     00123620 00000017
> IDT=     00123640 000007ff
> CR0=00050033 CR2=00000000 CR3=00000000 CR4=00000000
> CCS=0000000c CCD=0012c600 CCO=SUBL
> FCW=037f FSW=0000 [ST=0] FTW=00 MXCSR=00001f80
> FPR0=0000000000000000 0000 FPR1=0000000000000000 0000
> FPR2=0000000000000000 0000 FPR3=0000000000000000 0000
> FPR4=0000000000000000 0000 FPR5=0000000000000000 0000
> FPR6=0000000000000000 0000 FPR7=0000000000000000 0000
> XMM00=00000000000000000000000000000000
> XMM01=00000000000000000000000000000000
> XMM02=00000000000000000000000000000000
> XMM03=00000000000000000000000000000000
> XMM04=00000000000000000000000000000000
> XMM05=00000000000000000000000000000000
> XMM06=00000000000000000000000000000000
> XMM07=00000000000000000000000000000000
> Aborted
> silence:/images$
> Any idea what's going wrong here?
> Thanks,
> Karel
> PS: patch to ticker looks like:
> Index: init.c
> RCS file: /usr1/CVS/rtems/testsuites/samples/ticker/init.c,v
> retrieving revision 1.12
> diff -u -r1.12 init.c
> --- init.c    4 Sep 2003 18:53:41 -0000    1.12
> +++ init.c    30 Jan 2006 07:48:58 -0000
> @@ -38,7 +38,7 @@
>    rtems_status_code status;
>    rtems_time_of_day time;
> -  puts( "\n\n*** CLOCK TICK TEST ***" );
> +  puts( "\n\n*** CLOCK TICK TEST (HACKED!) ***" );
>    time.year   = 1988;
>    time.month  = 12;
> @@ -68,7 +68,9 @@
>    status = rtems_task_start( Task_id[ 1 ], Test_task, 1 );
> +  status = rtems_task_wake_after( get_ticks_per_second() );
>    status = rtems_task_start( Task_id[ 2 ], Test_task, 2 );
>    status = rtems_task_start( Task_id[ 3 ], Test_task, 3 );
>    status = rtems_task_delete( RTEMS_SELF );
> Index: tasks.c
> RCS file: /usr1/CVS/rtems/testsuites/samples/ticker/tasks.c,v
> retrieving revision 1.11
> diff -u -r1.11 tasks.c
> --- tasks.c    30 Mar 2004 11:12:01 -0000    1.11
> +++ tasks.c    30 Jan 2006 07:48:58 -0000
> @@ -32,6 +32,8 @@
>    status = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, &tid );
>    task_index = task_number( tid );
> +  put_name( Task_name[ task_index ], FALSE);
> +/*   printf(": ticks per second: %d\n", get_ticks_per_second() ); */
>    for ( ; ; ) {
>      status = rtems_clock_get( RTEMS_CLOCK_GET_TOD, &time );
>      if ( time.second >= 35 ) {
> @@ -40,6 +42,7 @@
>      put_name( Task_name[ task_index ], FALSE );
>      print_time( " - rtems_clock_get - ", &time, "\n" );
> +/*     printf("...wake after %d ticks\n", task_index * 5 *
> get_ticks_per_second()); */
>      status = rtems_task_wake_after( task_index * 5 *
> On Sat, 28 Jan 2006, Karel Gardas wrote:
>> Hello,
>> short followup. I've tested also these configurations with today CVS
>> head, but all were broken:
>> vanilla gcc3.4.5 + vanilla newlib1.14.0
>> patched gcc4.0.0 + patched newlib1.13.0
>> (gcc-4.0.0-rtems-20050502.diff, newlib-1.13.0-rtems-20050512.diff)
>> vanilla gcc3.4.3 + patched newlib1.13.0
>> (newlib-1.13.0-rtems-20050512.diff)
>> patched gcc3.4.0 + patched newlib1.13.0
>> (gcc-3.4.0-rtems-20040510.diff, newlib-1.13.0-rtems-20050512.diff)
>> everything with patched binutils 2.16.1
>> (binutils-2.16.1-rtems-20050816.diff)
>> Is there anybody here running some kind of older CVS head where
>> ticker runs fine? I'm asking, since I know it was running fine at
>> least a bit before August 23 2005, when I submited patch for pc386
>> automatic timer functionality detection.
>> Thanks,
>> Karel
>>> Joel,
>>> IIRC you've had some issues with ticker test for pc386 BSP on CVS
>>> head with latest tool-chain. I remember you've been talking about
>>> miscompilation. Now, I've used vanilla gcc4.0.2, vanilla
>>> newlib1.14.0 and binutils 2.16.1 +
>>> binutils-2.16.1-rtems-20050816.diff patch. I've compiled pc386 BSP
>>> from today sources and while testing I've found that ticker.exe
>>> prints first four lines:
>>> TA1 - tm_get - 09:00:00   12/31/1988
>>> TA2 - tm_get - 09:00:00   12/31/1988
>>> TA3 - tm_get - 09:00:00   12/31/1988
>>> then "blocks", but it seems processor is strangely "working" since
>>> after some time I see it is corrupting content of the console (VGA)
>>> RAM. i.e. I see few random chars with few random colors spread over
>>> the screen.
>>> My question is: have you already solved this your "ticker
>>> miscompilation" issue or is it still unsolved and I'm hitting
>>> exactly this issue?
>>> Thanks,
>>> Karel
>>> Karel Gardas                  kgardas at objectsecurity.com
>>> ObjectSecurity Ltd.           http://www.objectsecurity.com
