automatic NIC driver selection.
Karel Gardas kgardas at objectsecurity.com
Tue Jan 31 08:35:56 UTC 2006
On Mon, 30 Jan 2006, Till Straumann wrote:
> Karel Gardas wrote:
>> Hello,
>> has anybody here already hacked RTEMS to support some kind of automatic NIC
>> driver selection? The purpose is to compile once net-enabled binaries and
>> runs on two (or more) machines (pc386 BSP) with different NIC.
>> Thanks,
>> Karel
>> ObjectSecurity Ltd.           http://www.objectsecurity.com
> Yes.
> Hacked is the appropriate word.
> I write a wrapper 'attach' method which does the driver selection
> (the MVME6100 BSP I recently wrote also does link detection
> there), modifies the 'ifcfg->attach' and 'ifcfg->name' fields and
> vectors to the real 'attach'.
Sounds good! Do you plan to make your code freely available? Or is it
already somewhere in RTEMS tree?
Thanks,
Karel
