gen405 status?
Chris Caudle chris at chriscaudle.org
Tue Jan 31 22:35:14 UTC 2006
On Tue, January 31, 2006 2:39 pm, Joel Sherrill wrote:
> What tools are you using? [re: build errors with gen405]
I have both i386 and PPC binaries installed on my machine.
The PPC and native tools are:
rtems-4.7-autoconf-rtems-2.59-4
rtems-4.7-automake-rtems-1.9.6-0
rtems-4.7-rtems4.7-base-gcc-gcc4.0.1newlib1.13.0-4
rtems-4.7-rtems4.7-base-binutils-2.16.1-3
rtems-4.7-powerpc-rtems4.7-c++-gcc4.0.1newlib1.13.0-4
rtems-4.7-powerpc-rtems4.7-gcc-gcc4.0.1newlib1.13.0-4
rtems-4.7-powerpc-rtems4.7-binutils-2.16.1-3
Those were pulled down pre-built from ftp.rtems.com, I did not rebuild any
of the tools.
> I do not know if it runs as I have no way to test it.  It is likely to
> require some modifications for any particular 405 board
> if it is anything like other System On CPU BSPs.
Likely, although changes should be minimal.  System clock frequency and
memory configuration would be the most likely, and it looks like gen405 is
already close to what I have in mind.
> known good conversion of the gen405 to new exceptions would be welcomed
I was just listening in on the periphery when the old exception/new
exception discussions were occuring on the mailing list.  Is there a
concise summary somewhere detailing the changes needed to move from old
exception model to new exceptions?
-- Chris Caudle
