Interrupts Disabled After First Context Switch
Kirspel, Kevin {Engineering - Osmetech CCD}
kevin.kirspel at osmetech.com
Fri Jan 6 14:25:24 UTC 2006
4.6.0
I see that the 4.6.5 version does not have the disable. I will upgrade
my rtems today.
Kevin Kirspel
Osmetech
235 Hembree Park Drive
Roswell GA, 30076
770-510-4444 x4568
-----Original Message-----
[mailto:joel.sherrill at OARcorp.com]
Sent: Friday, January 06, 2006 8:21 AM
To: Ian Caddy
Cc: Kirspel, Kevin {Engineering - Osmetech CCD}; rtems-users at rtems.com
Subject: Re: Interrupts Disabled After First Context Switch
Ian Caddy wrote:
> Hi Kevin,
> Which version of RTEMS are you running. We have been looking through
> watchdoginsert.c for another problem and in my version, which is from
> 4.6.5 there is no _ISR_Disable( level ) after the restart.
Ditto for the code on the head of CVS. Which version of RTEMS is this?
Or which CVS Id is watchdoginsert.c?
> That definitely looks wrong to me. You can not have 2 disables
without
> an enable in between them. In fact looking through that code, if the
> restart is invoked, you will get more _ISR_Disable( level ) than just
> the 2 as well.
Right.
> The cpukit/score/src/watchdoginsert.c in the 4.6.5 release is correct
if
> you want to have a look at that.
> regards,
> Ian Caddy
> Kirspel, Kevin {Engineering - Osmetech CCD} wrote:
>> I'm not sure this is a bug but I tracked down my problem to
>> _Watchdog_Insert(). Below is the relevant code snippet. Upon
entering
>> watchdog insert the routine disables interrupts. This sets my
interrupt
>> level to 15 ( which blocks all interrupts ). The returned interrupt
>> level from the _ISR_Disable() call shows that the previous interrupt
>> level to be zero. This is correct. It then disables the interrupts
>> again right after the restart label. Since the interrupt level is
>> current 15 the returned interrupt level from the _ISR_Disable() is
now
>> 15. When it finally enables interrupts at the end, the level is set
to
>> 15 masking all interrupts. To fix the problem I commented out the
>> _ISR_Disable() right below the restart label. Is this a bug or is
>> intended to work this way?
>> void _Watchdog_Insert(
>> Chain_Control *header,
>> Watchdog_Control *the_watchdog
>> ISR_Level level;
>> Watchdog_Control *after;
>> unsigned32 insert_isr_nest_level;
>> Watchdog_Interval delta_interval;
>> insert_isr_nest_level = _ISR_Nest_level;
>> _ISR_Disable( level );
>> * Check to see if the watchdog has just been inserted by a
>> * higher priority interrupt. If so, abandon this insert.
>> if ( the_watchdog->state != WATCHDOG_INACTIVE ) {
>> _ISR_Enable( level );
>> return;
>> the_watchdog->state = WATCHDOG_BEING_INSERTED;
>> _Watchdog_Sync_count++;
>> restart:
>> delta_interval = the_watchdog->initial;
>> _ISR_Disable( level ); //I commented this Disable to fix problem
>> for ( after = _Watchdog_First( header ) ;
>> after = _Watchdog_Next( after ) ) {
>> if ( delta_interval == 0 || !_Watchdog_Next( after ) )
>> break;
>> if ( delta_interval < after->delta_interval ) {
>> after->delta_interval -= delta_interval;
>> break;
>> delta_interval -= after->delta_interval;
>> * If you experience problems comment out the _ISR_Flash line.
>> * 3.2.0 was the first release with this critical section
>> redesigned.
>> * Under certain circumstances, the PREVIOUS critical section
>> algorithm
>> * used around this flash point allowed interrupts to execute
>> * which violated the design assumptions. The critical section
>> * mechanism used here WAS redesigned to address this.
>> _ISR_Flash( level );
>> if ( the_watchdog->state != WATCHDOG_BEING_INSERTED ) {
>> goto exit_insert;
>> if ( _Watchdog_Sync_level > insert_isr_nest_level ) {
>> _Watchdog_Sync_level = insert_isr_nest_level;
>> goto restart;
>> _Watchdog_Activate( the_watchdog );
>> the_watchdog->delta_interval = delta_interval;
>> _Chain_Insert_unprotected( after->Node.previous,
&the_watchdog->Node
>> the_watchdog->start_time = _Watchdog_Ticks_since_boot;
>> exit_insert:
>> _Watchdog_Sync_count--;
>> Kevin Kirspel
>> Osmetech 235 Hembree Park Drive
>> Roswell GA, 30076
>> 770-510-4444 x4568
>> From: Joel Sherrill <joel at OARcorp.com>
>> [mailto:joel.sherrill at OARcorp.com] Sent: Thursday, January 05, 2006
>> 4:44 PM
>> To: Kirspel, Kevin {Engineering - Osmetech CCD}
>> Cc: rtems-users at rtems.com
>>> During _Thread_Dispatch() I was printing the state of the SR
register.
>> I
>>> found that by the third context switch the interrupts were disabled
>>> going into _Thread_Dispatch(). So when _ISR_Disable() is called it
>>> returns the SR register with interrupts disabled. Since the
>>> _ISR_Enable() routine just sets the SR register with the given
level,
>>> interrupts are disabled even after the _ISR_Enable() call. Is it
>>> possible to enter the _Thread_Dispatch() routine while interrupts
are
>>> disable ( i.e. _ISR_Disable() was called prior to _Thread_Dispatch()
>> Yes. Interrupt level is maintained across context switches on a per
>> thread basis.
>> I suspect that the third context switch you see is actually from
>> __ISR_Dispatch and that the level is somehow not being maintained
across
>> a preemption from ISR.
>> The sequence should be something like this for your test:
>> (1) 1st context switch (initialization to 1st thread)
>> (2) 1st thread to IDLE (wake after)
>> ... clock tick isrs
>> (3) IDLE to 1st thread FROM ISR!!
>> The FROM ISR on (3) is critical. That puts you through the tail of
>> __ISR_Handler and possibly needing some magic. On other CPUs, that
>> code is tricky. The SH code is straightforward but might be missing
>> something on the SH3/4.
>>> Kevin Kirspel
>>> Roswell GA, 30076
>>> 770-510-4444 x4568
>>> 1:04 PM
>>>> 1) Renesas SH-3 but it's pretty much the same as the SH-4.
>>>> 2) the rtems_interrupt_disable() routine returns the value in the
SR
>>>> register of the sh-3/4. The SR register contains a BL bit that
masks
>>>> interrupts. It also contains an interrupt level mask that prevents
>>> any
>>>> interrupt lower than the level in the SR register from executing.
The
>>>> SH4 port sets the interrupt level to 15 to mask all interrupts (
>>>> rtems_interrupt_disable ). Upon the printf statement below, the
>>>> interrupt level in the SR register is set to 15 masking all
>>> interrupts.
>>>> 3)Yes.
>>>> Case 1: using interrupt mask level 15 to disable interrupts. (
>>> interrupt
>>>> masks bits are bits 4-7 which is 0 before and F after).
>>>> INT BEFORE: 0x40001000
>>>> INT AFTER: 0x400011F1
>>>> Case 2: using interrupt BL bit to disable interrupts. ( interrupt
BL
>>> bit
>>>> is bit 28 which is 0 before and 1 after).
>>>> INT AFTER: 0x50001101
>>> Is BL implicitly modified by an interrupt? I don't know the SH well
>>> enough to trace the code in my head but since you are doing a
>>> delaying/blocking wake_after, there will be a context switch to
IDLE,
>>> then some clock tick ISRs, then a preempt of IDLE via the
>> __ISR_Handler
>>> routine in cpu_asm.c. If the BL bit is not preserved across the (a)
>>> context switch or (b) interrupt preemption, then it might be what
you
>>> are seeing.
>>> I do not think it is (a) because that is a simple load/store of the
>> sr.
>>> The __ISR_Handler code is always tricky to get right but I don't see
>> how
>>> it could be messed up either.
>>> To eliminate some possibilities and assuming this is a single task
>> test,
>>> change the wake after(100) to wake after(0). And do not print until
>>> after all of the interrupt level changes. I suspect it is the
>> interrupt
>>> context switch somehow. Just a guess.
>>>> Kevin Kirspel
>>>> Roswell GA, 30076
>>>> 770-510-4444 x4568
>>>> 11:20 AM
>>>>> Upon entering a task, the interrupts at the hardware level are
>>>> enabled.
>>>>> After a call to rtems_task_wake_after() the interrupts are
disabled
>>>> and
>>>>> remain disabled while the task is running. What part of the code
>>>> should
>>>>> I look at to diagnose this issue? It seems that interrupts get
>>>> disabled
>>>>> before the task switch is performed.
>>>>> The code sample below illustrates what I am doing. At the first
>>>>> printf(), the interrupts are enabled. After the second printf(),
the
>>>>> interrupts are disabled.
>>>>> rtems_task GUITask ( rtems_task_argument ignored )
>>>>> //Local Varaibles
>>>>> rtems_interrupt_level level;
>>>>> /* Wait 100ms til everyone is up and running */
>>>>> rtems_interrupt_disable(level);
>>>>> rtems_interrupt_enable(level);
>>>>> printf( "\r\nINT BEFORE: %08lX", level );
>>>>> rtems_task_wake_after( 10 );
>>>>> printf ( "\r\nINT AFTER: %08lX", level );
>>>> I have more questions than answers.
>>>> rtems_interrupt_enable/disable are implemented as inline assembly
>>>> language routines. They are port specific which leads to
>>>> (1) Which CPU are you using?
>>>> There is no guarantee on the contents of level after calling enable
>>>> so
>>>> (2) are you sure they are really off?
>>>> (3) can you print out the status register or whatever it is on this
>>> CPU
>>>> and we really check?
>>>>> Kevin Kirspel
>>>>> Roswell GA, 30076
>>>>> 770-510-4444 x4568
joel at OARcorp.com On-Line Applications Research
