Help to hello_world example
Karel Gardas kgardas at objectsecurity.com
Sat Jan 21 12:11:56 UTC 2006
I assume you've compiled some RTEMS BSP, haven't you? So you have also
probably installed it by `make install' and it was installed into prefix
(--prefix configure command). So in the installation prefix please start
looking for *.inc -- I don't have any BSP installed here now, so you need
to find the right target directory yourself. (IIRC it's something like
<prefix>/make or something like that...)
Cheers,
Karel
On Sat, 21 Jan 2006, Matteo wrote:
> Ok I see the readme file but i don't know where to set RTEMS_MAKEFILE_PATH and I
> don't find the Makefile.inc on my system It would be in rtems directory?
> Thanks
> Scrive Karel Gardas <kgardas at objectsecurity.com>:
>>> Hi
>>> I install rtems in /opt/rtems-4.6/ unpackaging the rpm file, I untar the
>>> example and I would like to launch the hello_world  so I launch
>>> /example/hello_world_c/make but I have a lot of error !
>>> matteo at matteo:~/projects/rtems/examples-4.6.5/hello_world_c$ make
>>> Makefile:33: /opt/rtems-4.6/bin/Makefile.inc: No such file or directory
>>> Makefile:35: no file name for `include'
>>> Makefile:36: /make/leaf.cfg: No such file or directory
>>> make: *** No rule to make target `/make/leaf.cfg'.  Stop.
>>> IT's a problem of PATH ?
>>> What I can do ?
>> You need to correctly set your RTEMS_MAKEFILE_PATH. See your example
>> Makefile for more information.
>> Cheers,
>> Karel
>> ObjectSecurity Ltd.           http://www.objectsecurity.com
