[pc386 BSP] ticker.exe issue (CVS head)
Karel Gardas
kgardas at objectsecurity.com
Sat Jan 28 21:56:05 UTC 2006
Hello,
short followup. I've tested also these configurations with today CVS head,
but all were broken:
vanilla gcc3.4.5 + vanilla newlib1.14.0
patched gcc4.0.0 + patched newlib1.13.0 (gcc-4.0.0-rtems-20050502.diff, newlib-1.13.0-rtems-20050512.diff)
vanilla gcc3.4.3 + patched newlib1.13.0 (newlib-1.13.0-rtems-20050512.diff)
patched gcc3.4.0 + patched newlib1.13.0 (gcc-3.4.0-rtems-20040510.diff, newlib-1.13.0-rtems-20050512.diff)
everything with patched binutils 2.16.1 (binutils-2.16.1-rtems-20050816.diff)
Is there anybody here running some kind of older CVS head where ticker
runs fine? I'm asking, since I know it was running fine at least a bit
before August 23 2005, when I submited patch for pc386 automatic timer
functionality detection.
Thanks,
Karel
On Sat, 28 Jan 2006, Karel Gardas wrote:
> Joel,
> IIRC you've had some issues with ticker test for pc386 BSP on CVS head with
> latest tool-chain. I remember you've been talking about miscompilation. Now,
> I've used vanilla gcc4.0.2, vanilla newlib1.14.0 and binutils 2.16.1 +
> binutils-2.16.1-rtems-20050816.diff patch. I've compiled pc386 BSP from today
> sources and while testing I've found that ticker.exe prints first four lines:
> *** CLOCK TICK TEST ***
> TA1 - tm_get - 09:00:00 12/31/1988
> TA2 - tm_get - 09:00:00 12/31/1988
> TA3 - tm_get - 09:00:00 12/31/1988
> then "blocks", but it seems processor is strangely "working" since
> after some time I see it is corrupting content of the console (VGA)
> RAM. i.e. I see few random chars with few random colors spread over
> the screen.
> My question is: have you already solved this your "ticker miscompilation"
> issue or is it still unsolved and I'm hitting exactly this issue?
> Thanks,
> Karel
> Karel Gardas kgardas at objectsecurity.com
> ObjectSecurity Ltd. http://www.objectsecurity.com
