RTEMS-CVS is broken
Ralf Corsepius ralf.corsepius at rtems.org
Thu Jul 13 15:37:48 UTC 2006
On Thu, 2006-07-13 at 10:24 -0500, Joel Sherrill wrote:
> Ralf Corsepius wrote:
> >Thomas,
> >your last week's monster check in into RTEMS cvs screwed up RTEMS badly:
> >Since your patch, all BSPs, I've tried so far, fail with an error
> >similar to this:
> >./../../../../armulator/lib/include/rtems/confdefs.h:385: error:
> >'ATA_DRIVER_TASK_DEFAULT_PRIORITY' undeclared here (not in a function)
> >gmake[5]: *** [init.o] Error 1
> What configure command are you using?
In the case above:
<dir>/rtems/configure  --target=arm-rtems4.7 --enable-maintainer-mode
--enable-posix
> >Furthermore, checking what you checked in to confdefs.h, makes me
> >believe you broke cpukit:
> >E.g. this
> >+#ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
> >+#include <libchip/ata.h>
> >+#endif
> >accesses libchip/ata.h (not part of cpukit).
> This may not be so bad since it should only be turned on by code which knows
> the libchip ATA driver is supported on that BSP.
Sorry I consider the above to be truely unacceptably bad design:
You are turning the hierarchies upside down:
1. libchip drivers are "plugins", a BSP has to "glue them together".
cpukit should not need to know anything about a driver.
2. Conditionally including files outside of cpukit from inside of
cpukit, renders successful building a random accident.
>  It would be more
> correct long
> term to move the ata.h file to cpukit if it is a "standard RTEMS driver
> interface" and (hopefully) doesn't suck in a lot more.
The ata stuff is i386 specific.
> >Furthermore, you missed to add changelog entries.
> That's not good. :(
Yes, it renders reverting these changes a pain.
Ralf
