RTEMS-CVS is broken
Fri Jul 14 00:18:29 UTC 2006
Joel Sherrill wrote:
> At first thought, this seems reasonable.    confdefs.h can stick to the
> basics in CPU Kit.
Why do we need to use confdefs.h ?
I have used the following type of BSP specific code in the past without
the need to adjust the static driver table. The code uses
'rtems_io_register_driver'. I am yet to see the need for the change in
confdefs.h.
Regards
#include <.....>
  * Provide the bsp IDE functions.
boolean
my_bsp_ide_probe (int minor)
ide_ctrl_fns_t my_bsp_ide_ctrl_fns =
   my_bsp_ide_probe,
   my_bsp_ide_initialise,
   my_bsp_ide_control,
   my_bsp_ide_read_reg,
   my_bsp_ide_write_reg,
   my_bsp_ide_read_block,
   my_bsp_ide_write_block,
   my_bsp_ide_config_io_speed
  * IDE controllers Table
ide_controller_bsp_table_t IDE_Controller_Table[] =
     "/dev/ide",
     IDE_STD,           /* standard IDE controller */
     &my_bsp_ide_ctrl_fns,
     NULL,              /* probe for IDE standard registers */
     FALSE,             /* not (yet) initialized */
     0,                 /* base I/O address for first IDE controller */
     FALSE,0,           /* not (yet) interrupt driven */
     NULL
unsigned long IDE_Controller_Count = 1;
static rtems_filesystem_mount_table_entry_t *mt_entry;
extern rtems_filesystem_operations_table msdos_ops;
rtems_bdbuf_config rtems_bdbuf_configuration[] =
   { 512, 20, 0 }
int rtems_bdbuf_configuration_size = 1;
static rtems_device_major_number ide_major;
static rtems_device_major_number ata_major;
#define MKDIR_MODE  (S_IRWXU | S_IRGRP | S_IXGRP | S_IROTH | S_IXOTH)
  * Called by other code in the BSP during initialisation.
int
my_bsp_ide_init ()
   rtems_driver_address_table ide_drv = \
                                IDE_CONTROLLER_DRIVER_TABLE_ENTRY;
   rtems_driver_address_table ata_drv = \
                                ATA_DRIVER_TABLE_ENTRY;
   rtems_status_code          sc;
    * Add specific BSP code to detect the hardware and a drive. This
    * includes setting up the hardware specific to the target, eg
    * chip selects, buses etc.
   if (rtems_rootfs_mkdir ("/bsp", MKDIR_MODE) < 0)
     printf ("my-bsp-ide: could not create the mount point\n");
     return 0;
   sc = rtems_io_register_driver (7, &ide_drv, &ide_major);
   if (sc != RTEMS_SUCCESSFUL)
     printf ("my-bsp-ide: could not register the IDE driver: %s\n",
             rtems_status_text (sc));
     return 0;
   sc = rtems_io_register_driver (8, &ata_drv, &ata_major);
     printf ("my-bsp-ide: could not register the ATA driver: %s\n",
     return 0;
   sc = rtems_ide_part_table_initialize ("/dev/hda");
     printf ("my-bsp-ide: failed to read the partition table: %s\n",
     return 0;
   if (mount (&mt_entry, &msdos_ops, RTEMS_FILESYSTEM_READ_WRITE,
              "/dev/hda1", "/bsp") < 0)
     printf ("my-bsp-ide: could not mount the drive: %s\n",
             strerror (errno));
     return 0;
   return 1;
