Xilinx IP core drivers for RTEMS- Keith Robertson still around?
Thomas Doerfler (nt) Thomas.Doerfler at imd-systems.de
Tue Jul 18 16:05:23 UTC 2006
Robert,
this really looks interesting. we were in contact with keith aroung
chrismas but we drowned in our work right from the start of this year,
so we lost contact again about the ml403 BSP.
Can you (or Keith) provide a more detailed outline about the neccesary
xilinx configuration?
I have checked the patch you provided, it looks interesting, but it
turns the gen405 BSP into a ml403 BSP, instead of defining a derivate.
But I think it will not be SO difficult to devide things again so the
BSP will support either a gen405 board 8whatever it is now) or a ml403.
wkr,
Thomas .
Robert S. Grimes schrieb:
> Hi Greg,
> I'm in the same boat as you.  Keith has sent me his diffs, which I
> include here.  Note that they are against a little older version
> (V4.6.5) of RTEMS, and should work on a suitably configured Xilinx ml403
> board.  You'll have to make sure your V4 configuration is compatible
> with his stuff, or change one side or another...
> Be forewarned - things are much more tricky here in V4 land. Because of
> the flexibility of the V4, you have many more variables.  When I used
> Keith's work, the simplest RTEMS application simply worked!  However, in
> looking at things afterwards, I realized how random that was...
> I started with the Xilinx ml403 development/evaluation board.  As
> delivered, it is a pretty full-fledged configuration designed to show
> off all the V4 and ml403 features.  One thing I noticed early on is that
> some of the IP used in that configuration, specifically the serial port
> and the Ethernet MAC, would cost extra (iirc, $2K for the serial port,
> and $5 for the MAC).  I sure didn't feel like paying $2K for a console
> port!  Fortunately, the provide the uart lite component, so I did the
> necessary substitution.  Here is where the randomness kicks in - for
> whatever reason, Keith had done the same, so lo and behold, things worked!
> It gets more complicated, however.  For me, I can't justify spending $5K
> for a core that takes up 25% of the FPGA fabric, /especially when there
> are two hard TEMACs on the darn chip to begin with/!  (I'm still a bit
> hot under the collar about how difficult getting the TEMAC up has been,
> especially because one would reasonably had assumed that such a
> highly-touted feature would have been demonstrated in an evaluation
> board!!!)  So I'll have to modify what Keith has done anyway to use the
> TEMAC.
> Anyway, I've been off it for a little while, but will be picking up
> steam again, especially after my design review on this project August
> 1&2, so if interested, we can perhaps help each other a bit.  Be
> forewarned, I'm a novice with RTEMS, though I won't be for much longer...
> -Bob
> Keith's stuff:
> Attached is his diff against a clean 4.6.5 - here are his comments
>    Here's the diff's against a clean 4.6.5.  I've had to manually edit
>    the output of my svn diff command to only get changes specific to
>    the gen405 drivers I've spoken about.  I believe it should work though.
>    All changes are made available under the standard rtems license (ie
>    GPL plus rtems exception).
>    The main changes are the following:
>    Xilinx opb interrupt controller:
>    c/src/lib/libbsp/powerpc/gen405/opbintctrl/opbintctrl.[ch]
>    Xilinx uart lite driver:
>    c/src/lib/libbsp/powerpc/gen405/console/consolelite.c
>    Xilinx ethernet driver:
>    c/src/lib/libbsp/powerpc/gen405/network/network.[ch]
>    There are three other types of changes:
>    1) Makefile.am changes to make the whole thing compile
>    2) A few changes that were spoken about on the mailing list in July
>    (essentially bugs in the gen405 port AFAICT).
>    http://www.rtems.com/ml/rtems-users/2005/july/msg00023.html
>    http://www.rtems.com/ml/rtems-users/2005/july/msg00008.html
>    3) Bsp startup / connection to driver files
>    (gen405/network/network.c, gen405/include/bsp.h)
> gregory.menke at gsfc.nasa.gov wrote:
>> Hi,
>> This message is directed to Keith Robertson with regard to a message on
>> the rtems mail list in Dec 2005 where he indicated he had some RTEMS
>> code written to support Virtex-4 PPC hardware, specifically the
>> interrupt controller, uart & ethernet.  If possible, I'd like to get
>> copies of the code since we have a high priority effort underway using
>> those parts, and RTEMS is the OS.
>> Thanks,
>> Greg
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at:
     http://www.imd-systems.de/pgpkey_en.html
