Xilinx IP core drivers for RTEMS- Keith Robertson still around?
gregory.menke at gsfc.nasa.gov gregory.menke at gsfc.nasa.gov
Tue Jul 18 16:32:34 UTC 2006
Thanks Robert!
Exactly what I needed.  Over the next few days I will be working the
patches in and comparing to the firmware as its been specified in our
board- its quite similar to an ML403.  We do have flexibility wrt the
Virtex firmware so reconfigs there will not be an issue.  I think the
goal will be to create a proper bsp to support our board.  The initial
tests will be RTEMS running our flight software, taking data in over a
serial port and transmitting out of ethernet.
I'd be happy to share the RTEMS portions of the work & collaborate
wherever its feasable.  We have to be running & stable by the end of
August so development is going to be brisk over the next couple weeks.
Regards,
Greg
Robert S. Grimes writes:
 > Hi Greg,
 > I'm in the same boat as you.  Keith has sent me his diffs, which I
 > include here.  Note that they are against a little older version
 > (V4.6.5) of RTEMS, and should work on a suitably configured Xilinx ml403
 > board.  You'll have to make sure your V4 configuration is compatible
 > with his stuff, or change one side or another...
