Xilinx IP core drivers for RTEMS- Keith Robertson still around?
Robert S. Grimes rsg at alum.mit.edu
Tue Jul 18 17:52:09 UTC 2006
Consider yourself kicked - with all due respect, of course!
Ed Sutter wrote:
> Great.
> I have code examples for hooking up RTEMS to uMon, plus I've hooked
> up TFS to RTEMS FS also.  It hasn't been heavily tested, but if you
> think you can use it lemme know and I'll try to find it.
> Maybe that will *finally* kick me in the butt enough to put this
> info on the RTEMS Wiki also.
> Ed
> Robert S. Grimes wrote:
>> Hi Ed,
>> Oh, yeah - you did - works great, too!
>> -Bob
>> Ed Sutter wrote:
>>> Bob,
>>> I gave you what I have for the ML403/micromonitor stuff right?
>>> If you need help with that, lemme know.
>>> Ed Sutter
>>>> Hi Greg,
>>>> Please, less formality - Bob is fine by me!
>>>> Sounds like I'll be following you, I guess!  I had originally (as
>>>> in earlier today) thought I'd finish my MicroMonitor work first,
>>>> but perhaps I should move RTEMS up first.  It doesn't really matter
>>>> too much for me, and hopefully I'll be able to contribute more -
>>>> given your schedule.
>>>> Do you have the TEMAC working yet?  Or are you using one of the
>>>> "soft" IP cores?  What serial port core are you using?
>>>> Take care,
>>>> gregory.menke at gsfc.nasa.gov wrote:
>>>>> Thanks Robert!
>>>>> Exactly what I needed.  Over the next few days I will be working the
>>>>> patches in and comparing to the firmware as its been specified in our
>>>>> board- its quite similar to an ML403.  We do have flexibility wrt the
>>>>> Virtex firmware so reconfigs there will not be an issue.  I think the
>>>>> goal will be to create a proper bsp to support our board.  The
>>>>> initial
>>>>> tests will be RTEMS running our flight software, taking data in
>>>>> over a
>>>>> serial port and transmitting out of ethernet.
>>>>> I'd be happy to share the RTEMS portions of the work & collaborate
>>>>> wherever its feasable.  We have to be running & stable by the end of
>>>>> August so development is going to be brisk over the next couple
>>>>> weeks.
>>>>> Regards,
>>>>> Greg
>>>>> Robert S. Grimes writes:
>>>>>  > Hi Greg,
>>>>>  >  > I'm in the same boat as you.  Keith has sent me his diffs,
>>>>> which I  > include here.  Note that they are against a little
>>>>> older version  > (V4.6.5) of RTEMS, and should work on a suitably
>>>>> configured Xilinx ml403  > board.  You'll have to make sure your
>>>>> V4 configuration is compatible  > with his stuff, or change one
>>>>> side or another...
