sparc stack and heap
Aleix Conchillo Flaqué aconchillo at ieec.fcr.es
Tue Jul 25 14:46:46 UTC 2006
Great. Thanks for the answer. I'll have a look at that, it seems the
cleanest way to do it.
Regards,
aleix
On 25 Jul 2006, at 16:11, Joel Sherrill wrote:
> The simplest think to do would be to edit the linkcmds and reserve
> an area after the BSS.  If you
> move the "end" symbols to after your reserved block, then it will
> just be ignored by the BSP
> when it is carving memory.
> You could do this in an application specific linkcmds and add -
> qnolinkcmds -T myLinkcmds
> to the gcc command that links your application.  It would avoid
> otherwise changing the
> BSP as installed by RTEMS.
> --joel
