Problems connecting two embedded boards running RTEMS
A.Jallad at surrey.ac.uk
Thu Jul 27 18:19:11 UTC 2006
Hi,
I am trying to make a simple ethernet connection between two embedded boards with a LEON processor running on each. I am trying to make a connection between the two boards running RTEMS. The server starts listening but the client fails to connect.
What irritates me most is that the connection works fine between a Linux machine and each of the two boards individually in any configuration (linux machine serving as server and RTEMS board as client and vice-versa).
The configuration for the client is:
#define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
#define CONFIGURE_EXECUTIVE_RAM_SIZE (512*1024)
#define CONFIGURE_MAXIMUM_SEMAPHORES 20
#define CONFIGURE_MAXIMUM_TASKS 20
#define CONFIGURE_MICROSECONDS_PER_TICK 10000
#define CONFIGURE_INIT_TASK_STACK_SIZE (10*1024)
#define CONFIGURE_INIT_TASK_PRIORITY 120
#define CONFIGURE_INIT_TASK_INITIAL_MODES (RTEMS_PREEMPT | \
RTEMS_NO_TIMESLICE | \
RTEMS_NO_ASR | \
RTEMS_INTERRUPT_LEVEL(0))
The network configuration file for the client is shown below:
//This is the client network config
* Network configuration
* EDIT THIS FILE TO REFLECT YOUR NETWORK CONFIGURATION *
* BEFORE RUNNING ANY RTEMS PROGRAMS WHICH USE THE NETWORK! *
* networkconfig.h,v 1.8 2001/08/31 18:11:43 joel Exp
#ifndef _RTEMS_NETWORKCONFIG_H_
#define _RTEMS_NETWORKCONFIG_H_
* The following will normally be set by the BSP if it supports
* a single network device driver. In the event, it supports
* multiple network device drivers, then the user's default
* network device driver will have to be selected by a BSP
* specific mechanism.
#ifndef RTEMS_BSP_NETWORK_DRIVER_NAME
#warning "RTEMS_BSP_NETWORK_DRIVER_NAME is not defined"
#define RTEMS_BSP_NETWORK_DRIVER_NAME "no_network1"
#endif
#ifndef RTEMS_BSP_NETWORK_DRIVER_ATTACH
#warning "RTEMS_BSP_NETWORK_DRIVER_ATTACH is not defined"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH 0
#endif
/* #define RTEMS_USE_BOOTP */
#include <bsp.h>
* Define RTEMS_SET_ETHERNET_ADDRESS if you want to specify the
* Ethernet address here. If RTEMS_SET_ETHERNET_ADDRESS is not
* defined the driver will choose an address.
#define RTEMS_SET_ETHERNET_ADDRESS
#if (defined (RTEMS_SET_ETHERNET_ADDRESS))
/* static char ethernet_address[6] = { 0x08, 0x00, 0x3e, 0x12, 0x28, 0xb1 }; */
static char ethernet_address[6] = { 0x00, 0x80, 0x7F, 0x22, 0x61, 0x77 };
#endif
#ifdef RTEMS_USE_LOOPBACK
* Loopback interface
extern void rtems_bsdnet_loopattach();
static struct rtems_bsdnet_ifconfig loopback_config = {
"lo0", /* name */
rtems_bsdnet_loopattach, /* attach function */
NULL, /* link to next interface */
"127.0.0.1", /* IP address */
"255.0.0.0", /* IP net mask */
#endif
* Default network interface
static struct rtems_bsdnet_ifconfig netdriver_config = {
RTEMS_BSP_NETWORK_DRIVER_NAME, /* name */
RTEMS_BSP_NETWORK_DRIVER_ATTACH, /* attach function */
&loopback_config, /* link to next interface */
#else
NULL, /* No more interfaces */
#endif
#if (defined (RTEMS_USE_BOOTP))
NULL, /* BOOTP supplies IP address */
NULL, /* BOOTP supplies IP net mask */
#else
"192.168.1.66", /* IP address */
"255.255.255.0", /* IP net mask */
#endif /* !RTEMS_USE_BOOTP */
ethernet_address, /* Ethernet hardware address */
#else
NULL, /* Driver supplies hardware address */
#endif
0 /* Use default driver parameters */
struct rtems_bsdnet_config rtems_bsdnet_config = {
&netdriver_config,
rtems_bsdnet_do_bootp,
#else
NULL,
#endif
100, /* Default network task priority */
128*1024, /* Default mbuf capacity */
256*1024, /* Default mbuf cluster capacity */
#if (!defined (RTEMS_USE_BOOTP))
"rtems_client", /* Host name */
"localnet", /* Domain name */
"192.168.1.15", /* Gateway */
"192.168.1.15" , /* Log host */
{"192.168.1.15" }, /* Name server(s) */
{"192.168.1.15" }, /* NTP server(s) */
* For TFTP test application
#define RTEMS_TFTP_TEST_HOST_NAME "BOOTP_HOST"
#define RTEMS_TFTP_TEST_FILE_NAME "BOOTP_FILE"
#else
#define RTEMS_TFTP_TEST_HOST_NAME "XXX.YYY.ZZZ.XYZ"
#define RTEMS_TFTP_TEST_FILE_NAME "tftptest"
#endif
#endif /* _RTEMS_NETWORKCONFIG_H_ */
The server configuration is
RTEMS_NO_ASR | \
The networkconfig.h for the server is shown below:
//This is the server network config
#endif
#endif
#include <bsp.h>
#endif
"lo0", /* name */
#endif
#else
#endif
#else
"192.168.1.15", /* IP address */
#else
#endif
&netdriver_config,
#else
NULL,
#endif
"rtems_server", /* Host name */
"", /* Gateway */
"" , /* Log host */
{"" }, /* Name server(s) */
{"" }, /* NTP server(s) */
#else
#endif
Any help appreciated,
Regards,
Abdul
Abdul-Halim Jallad
Surrey Space Centre
