new processor port tips?
Allan Hessenflow allanh-rtems at kallisti.com
Thu Jul 27 20:29:18 UTC 2006
> >I'm working on porting RTEMS to an ARC.
> Nice to see a port underway.  What compiler and other tool versions are
> you using?
I'm using the gcc port from codito.com; it is based on gcc 3.4.5 and
binutils 2.15.  I've added an arc-rtems target to it, based on their
arc-elf32 target.
> I encourage you to submit it.
I hope I'll be able to, but it will be up to the company I'm working for.
> Do you have a simulator for the ARC?  If so, then the first version of
> linkcmds is
> the one used to link and run on the simulator.  Ditto for the start.S
> file -- it is the
> crt0.s.
I don't have a simulator (at least not that I know of - I do have some
Metaware tools, but I haven't noticed a simulator as part of them).  I
know I don't have a gcc target and simulator setup to work together.
> Using a simulator, you should then figure out how to do simple console
> output.
> You 1st goal is to run hello world because it requires you to initialize
> RTEMS
> and switch to the 1st thread.  Next is ticker since it adds interrupts
> to the mix.
Yep, that's the sequence I'm planning to do, except running on some real
hardware instead of a simulator.
> Start with the CVS head. :)
The next goal after getting rtems running is to run nanox.  I know nanox
has some rtems support in it; do you happen to know if that support would
be any further from working with the CVS head vs 4.6.6?
allan
Allan N. Hessenflow      allanh at kallisti.com
