Problems connecting two embedded boards running RTEMS
Thu Jul 27 21:22:08 UTC 2006
A.Jallad at surrey.ac.uk wrote:
> It is a timeout failure,
Are you on a subnet with nothing but the two RTEMS computers and the Linux
machine?
If so, is there anyway you could get a hub between them all and use
Ethereal?
--joel
> Regards,
> Abdul
> -----Original Message-----
> From: Camilo Alejandro Arboleda [mailto:mislistas.correo at gmail.com]
> Sent: 27 July 2006 20:51
> To: Jallad AHM Mr (PG/R - Surrey Space Centre)
> Cc: rtems-users at rtems.com
> Subject: Re: Problems connecting two embedded boards running RTEMS
> 2006/7/27, A.Jallad at surrey.ac.uk <A.Jallad at surrey.ac.uk>:
>> Hi,
>> I am trying to make a simple ethernet connection between two embedded boards with a LEON processor running on each. I am trying to make a connection between the two boards running RTEMS. The server starts listening but the client fails to connect.
> How does it fail? timeout? connection refused?
>> What irritates me most is that the connection works fine between a Linux machine and each of the two boards individually in any configuration (linux machine serving as server and RTEMS board as client and vice-versa).
