Problems connecting two embedded boards running RTEMS
A.Jallad at surrey.ac.uk A.Jallad at surrey.ac.uk
Thu Jul 27 21:44:41 UTC 2006
I have a direct connection between the RTEMS computers. I am using a cross-cable for connecting the boards together. The idea of using Ethereal is a good one. Any other thoughts of the possible cause of the problem?
Regards,
Abdul
-----Original Message-----
From: Brett Swimley [mailto:brett.swimley at aedbozeman.com]
Sent: 27 July 2006 22:30
To: Joel Sherrill
Cc: Jallad AHM Mr (PG/R - Surrey Space Centre);
mislistas.correo at gmail.com; rtems-users at rtems.com
Subject: Re: Problems connecting two embedded boards running RTEMS
Are you running through a switch? If you're connecting directly, do you
need a swap cable? (Perhaps your Linux box can perform an auto-crossover
on it's PHY but your RTEMS computers can't).
Brett
Joel Sherrill wrote:
> A.Jallad at surrey.ac.uk wrote:
>> It is a timeout failure,
> Are you on a subnet with nothing but the two RTEMS computers and the
> Linux
> machine?
> If so, is there anyway you could get a hub between them all and use
> Ethereal?
> --joel
>> Regards,
>> Abdul
>> From: Camilo Alejandro Arboleda [mailto:mislistas.correo at gmail.com]
>> Sent: 27 July 2006 20:51
>> To: Jallad AHM Mr (PG/R - Surrey Space Centre)
>> Cc: rtems-users at rtems.com
>> 2006/7/27, A.Jallad at surrey.ac.uk <A.Jallad at surrey.ac.uk>:
>>> Hi,
>>> I am trying to make a simple ethernet connection between two
>>> embedded boards with a LEON processor running on each. I am trying
>>> to make a connection between the two boards running RTEMS. The
>>> server starts listening but the client fails to connect.
>> How does it fail? timeout? connection refused?
>>> What irritates me most is that the connection works fine between a
>>> Linux machine and each of the two boards individually in any
>>> configuration (linux machine serving as server and RTEMS board as
>>> client and vice-versa).
