GNATS-1110: in_cksum_hdr error in PC386 BSP
Till Straumann
strauman at slac.stanford.edu
Mon Jul 3 21:54:15 UTC 2006
Eric Norum wrote:
> On Jul 1, 2006, at 3:40 AM, Till Straumann wrote:
>> I believe I caught this one.
>> Thanks to Danilliu for reporting this and his/(her?)
>> perseverance.
>> It is definitely a toolchain/optimization issue:
>> The BSD code does
>> header->checksum = 0;
>> header->checksum = ip_cksum_hdr(&header);
>> The inline ip_cksum_hdr() routine has inline assembly
>> and gcc doesn't consider that the assembly actually
>> could read 'header->checksum' (which it does) so it thinks the
>> header->checksum = 0 assignment is unnecessary
>> and optimizes it away :-(
>> Confirmed by disassembly of Danilliu's broken
>> and a working binary.
>> [ As soon as any 'real' subroutine (like a printf)
>> is called from ip_cksum_hdr() gcc realizes that
>> the header->checksum=0 assigment could have
>> side-effects and the problem goes away].
>> A memory barrier could resolve this.
> Here's what the GCC manual has to say on this issue:
> If your assembler instructions access memory in an unpredictable
> fashion, add `memory' to the list of clobbered registers. This will
> cause GCC to not keep memory values cached in registers across the
> assembler instruction and not optimize stores or loads to that memory.
> You will also want to add the `volatile' keyword if the memory affected
> is not listed in the inputs or outputs of the `asm', as the `memory'
> clobber does not count as a side-effect of the `asm'. If you know how
> large the accessed memory is, you can add it as input or output but if
> this is not known, you should add `memory'. As an example, if you
> access ten bytes of a string, you can use a memory input like:
> {"m"( ({ struct { char x[10]; } *p = (void *)ptr ; *p; }) )}.
> Note that in the following example the memory input is necessary,
> otherwise GCC might optimize the store to `x' away:
> int foo ()
> int x = 42;
> int *y = &x;
> int result;
> asm ("magic stuff accessing an 'int' pointed to by '%1'"
> "=&d" (r) : "a" (y), "m" (*y));
> return result;
> The example looks like it describes the in_cksum_hdr() problem. I
> made the following change:
> diff -u -r1.5 in_cksum.h
> --- machine/in_cksum.h 2 Sep 2003 21:31:16 -0000 1.5
> +++ machine/in_cksum.h 3 Jul 2006 14:06:25 -0000
> @@ -59,10 +59,11 @@
> register u_int sum = 0;
> #define ADD(n) \
> - __asm__ volatile ("addl " #n "(%2), %0" : "=r" (sum) : "0" (sum),
> "r" (ip))
> + __asm__ volatile ("addl " #n "(%2), %0" : "=r" (sum) : "0" (sum),
> "r" (ip), "m" (*ip))
> #define ADDC(n) \
> - __asm__ volatile ("adcl " #n "(%2), %0" : "=r" (sum) : "0" (sum),
> "r" (ip))
> + __asm__ volatile ("adcl " #n "(%2), %0" : "=r" (sum) : "0" (sum),
> #define MOP \
> __asm__ volatile ("adcl $0, %0" : "=r" (sum) : "0" (sum))
> To my surprise the compiler emits the same code before and after I
> made the change.
I can't confirm this. Using the construct *does* make the difference:
Compiling the snippet
void test(int *pi)
*pi = 0;
#ifdef USE_MEMB
asm volatile(""::"m"(*pi));
#endif
*pi = 3;
powerpc-rtems-gcc -O -c test.c; powerpc-rtems-objdump -d test.o
produces:
0: 38 00 00 03 li r0,3
4: 90 03 00 00 stw r0,0(r3)
8: 4e 80 00 20 blr
whereas
powerpc-rtems-gcc -O -c -DUSE_MEMB test.c; powerpc-rtems-objdump -d test.o
does what we want:
0: 38 00 00 00 li r0,0
8: 38 00 00 03 li r0,3
c: 90 03 00 00 stw r0,0(r3)
10: 4e 80 00 20 blr
I also tested i386-rtems-gcc with the same result. Same applies to
native gcc-3.2.3
I have on my linux box.
What compiler are you using? What target did you check? Note that PPC people
wont' experience PR1110 (look at the ppc implementation of in_cksum_hdr(),
the reading of the relevant data is done be interspersed C-code).
If you are testing the modified <in_cksum.h> beware of outdated versions
that might get picked up...
Cheers
-- T.
> Am I reading the GCC manual wrong? Does making this change fix things
> for you?
> Eric Norum <norume at aps.anl.gov <mailto:norume at aps.anl.gov>>
> Advanced Photon Source
> Argonne National Laboratory
> (630) 252-4793
