GNATS-1110: in_cksum_hdr error in PC386 BSP
Till Straumann
strauman at slac.stanford.edu
Wed Jul 5 18:35:15 UTC 2006
I just found another problem with
in_cksum_hdr (freebsd mailing list).
Currently, (i386, ppc) the algorithm is split into several
'asm' constructs and we assume that the carry bit
is preserved across these. This is not a valid assumption,
however.
We definitively should try harder to eliminate 'asm'
T.
Joel Sherrill wrote:
> I am going to rely on you guys to make a definitive statement when you
> have a
> fix. This has been a long thread and I have been away for 10 days.
> Eric,
> please commit the fix you all are happy with.
> --joel
> Till Straumann wrote:
>> Eric Norum wrote:
>>> On Jul 1, 2006, at 3:40 AM, Till Straumann wrote:
>>>> I believe I caught this one.
>>>> Thanks to Danilliu for reporting this and his/(her?)
>>>> perseverance.
>>>> It is definitely a toolchain/optimization issue:
>>>> The BSD code does
>>>> header->checksum = 0;
>>>> header->checksum = ip_cksum_hdr(&header);
>>>> The inline ip_cksum_hdr() routine has inline assembly
>>>> and gcc doesn't consider that the assembly actually
>>>> could read 'header->checksum' (which it does) so it thinks the
>>>> header->checksum = 0 assignment is unnecessary
>>>> and optimizes it away :-(
>>>> Confirmed by disassembly of Danilliu's broken
>>>> and a working binary.
>>>> [ As soon as any 'real' subroutine (like a printf)
>>>> is called from ip_cksum_hdr() gcc realizes that
>>>> the header->checksum=0 assigment could have
>>>> side-effects and the problem goes away].
>>>> A memory barrier could resolve this.
>>> Here's what the GCC manual has to say on this issue:
>>> If your assembler instructions access memory in an unpredictable
>>> fashion, add `memory' to the list of clobbered registers. This will
>>> cause GCC to not keep memory values cached in registers across the
>>> assembler instruction and not optimize stores or loads to that memory.
>>> You will also want to add the `volatile' keyword if the memory affected
>>> is not listed in the inputs or outputs of the `asm', as the `memory'
>>> clobber does not count as a side-effect of the `asm'. If you know how
>>> large the accessed memory is, you can add it as input or output but if
>>> this is not known, you should add `memory'. As an example, if you
>>> access ten bytes of a string, you can use a memory input like:
>>> {"m"( ({ struct { char x[10]; } *p = (void *)ptr ; *p; }) )}.
>>> Note that in the following example the memory input is necessary,
>>> otherwise GCC might optimize the store to `x' away:
>>> int foo ()
>>> int x = 42;
>>> int *y = &x;
>>> int result;
>>> asm ("magic stuff accessing an 'int' pointed to by '%1'"
>>> "=&d" (r) : "a" (y), "m" (*y));
>>> return result;
>>> The example looks like it describes the in_cksum_hdr() problem. I
>>> made the following change:
>>> diff -u -r1.5 in_cksum.h
>>> --- machine/in_cksum.h 2 Sep 2003 21:31:16 -0000 1.5
>>> +++ machine/in_cksum.h 3 Jul 2006 14:06:25 -0000
>>> @@ -59,10 +59,11 @@
>>> register u_int sum = 0;
>>> #define ADD(n) \
>>> - __asm__ volatile ("addl " #n "(%2), %0" : "=r" (sum) : "0"
>>> (sum), "r" (ip))
>>> + __asm__ volatile ("addl " #n "(%2), %0" : "=r" (sum) : "0"
>>> (sum), "r" (ip), "m" (*ip))
>>> #define ADDC(n) \
>>> - __asm__ volatile ("adcl " #n "(%2), %0" : "=r" (sum) : "0"
>>> (sum), "r" (ip))
>>> + __asm__ volatile ("adcl " #n "(%2), %0" : "=r" (sum) : "0"
>>> #define MOP \
>>> __asm__ volatile ("adcl $0, %0" : "=r" (sum) : "0" (sum))
>>> To my surprise the compiler emits the same code before and after I
>>> made the change.
>> I can't confirm this. Using the construct *does* make the difference:
>> Compiling the snippet
>> void test(int *pi)
>> *pi = 0;
>> #ifdef USE_MEMB
>> asm volatile(""::"m"(*pi));
>> #endif
>> *pi = 3;
>> powerpc-rtems-gcc -O -c test.c; powerpc-rtems-objdump -d test.o
>> produces:
>> 0: 38 00 00 03 li r0,3
>> 4: 90 03 00 00 stw r0,0(r3)
>> 8: 4e 80 00 20 blr
>> whereas
>> powerpc-rtems-gcc -O -c -DUSE_MEMB test.c; powerpc-rtems-objdump -d
>> test.o
>> does what we want:
>> 0: 38 00 00 00 li r0,0
>> 8: 38 00 00 03 li r0,3
>> c: 90 03 00 00 stw r0,0(r3)
>> 10: 4e 80 00 20 blr
>> I also tested i386-rtems-gcc with the same result. Same applies to
>> native gcc-3.2.3
>> I have on my linux box.
>> What compiler are you using? What target did you check? Note that PPC
>> people
>> wont' experience PR1110 (look at the ppc implementation of
>> in_cksum_hdr(),
>> the reading of the relevant data is done be interspersed C-code).
>> If you are testing the modified <in_cksum.h> beware of outdated versions
>> that might get picked up...
>> Cheers
>> -- T.
>>> Am I reading the GCC manual wrong? Does making this change fix
>>> things for you?
>>> Eric Norum <norume at aps.anl.gov <mailto:norume at aps.anl.gov>>
>>> Advanced Photon Source
>>> Argonne National Laboratory
>>> (630) 252-4793
