GNATS-1110: in_cksum_hdr error in PC386 BSP
Joel Sherrill
joel.sherrill at oarcorp.com
Wed Jul 5 20:12:52 UTC 2006
Till Straumann wrote:
> Eric Norum wrote:
>> I'm beginning to think that we really ought to just switch over to
>> the C version which was posted with the original problem report.
> I believe that in this particular case, fixing the ASM should be OK.
> We have now looked at this in detail and the proposed fixes
> (adding 'm' input and concatenating everyting into a single asm)
> should solve the problem. (And: yes, freebsd has updated versions
> [at least for i386]).
> This code is executed often and problems should surface immediately.
Can you commit the fix since you seem to be sure about the correct patch?
> I'm more concerned about other areas involving rare race conditions.
Yeah.. those are the nasty ones.
> T.
>>>> I just found another problem with
>>>> in_cksum_hdr (freebsd mailing list).
>>>> Currently, (i386, ppc) the algorithm is split into several
>>>> 'asm' constructs and we assume that the carry bit
>>>> is preserved across these. This is not a valid assumption,
>>>> however.
>>> Does their code base have a fixed version?
>>>> We definitively should try harder to eliminate 'asm'
>>> Unfortunately, it is a necessary evel.
>>>> T.
>>>>> I am going to rely on you guys to make a definitive statement when
>>>>> you have a
>>>>> fix. This has been a long thread and I have been away for 10
>>>>> days. Eric,
>>>>> please commit the fix you all are happy with.
>>>>> --joel
>>>>>> Eric Norum wrote:
>>>>>>> On Jul 1, 2006, at 3:40 AM, Till Straumann wrote:
>>>>>>>> I believe I caught this one.
>>>>>>>> Thanks to Danilliu for reporting this and his/(her?)
>>>>>>>> perseverance.
>>>>>>>> It is definitely a toolchain/optimization issue:
>>>>>>>> The BSD code does
>>>>>>>> header->checksum = 0;
>>>>>>>> header->checksum = ip_cksum_hdr(&header);
>>>>>>>> The inline ip_cksum_hdr() routine has inline assembly
>>>>>>>> and gcc doesn't consider that the assembly actually
>>>>>>>> could read 'header->checksum' (which it does) so it thinks the
>>>>>>>> header->checksum = 0 assignment is unnecessary
>>>>>>>> and optimizes it away :-(
>>>>>>>> Confirmed by disassembly of Danilliu's broken
>>>>>>>> and a working binary.
>>>>>>>> [ As soon as any 'real' subroutine (like a printf)
>>>>>>>> is called from ip_cksum_hdr() gcc realizes that
>>>>>>>> the header->checksum=0 assigment could have
>>>>>>>> side-effects and the problem goes away].
>>>>>>>> A memory barrier could resolve this.
>>>>>>> Here's what the GCC manual has to say on this issue:
>>>>>>> If your assembler instructions access memory in an unpredictable
>>>>>>> fashion, add `memory' to the list of clobbered registers. This
>>>>>>> will
>>>>>>> cause GCC to not keep memory values cached in registers across the
>>>>>>> assembler instruction and not optimize stores or loads to that
>>>>>>> memory.
>>>>>>> You will also want to add the `volatile' keyword if the memory
>>>>>>> affected
>>>>>>> is not listed in the inputs or outputs of the `asm', as the
>>>>>>> `memory'
>>>>>>> clobber does not count as a side-effect of the `asm'. If you
>>>>>>> know how
>>>>>>> large the accessed memory is, you can add it as input or output
>>>>>>> but if
>>>>>>> this is not known, you should add `memory'. As an example, if you
>>>>>>> access ten bytes of a string, you can use a memory input like:
>>>>>>> {"m"( ({ struct { char x[10]; } *p = (void *)ptr ; *p; }) )}.
>>>>>>> Note that in the following example the memory input is necessary,
>>>>>>> otherwise GCC might optimize the store to `x' away:
>>>>>>> int foo ()
>>>>>>> int x = 42;
>>>>>>> int *y = &x;
>>>>>>> int result;
>>>>>>> asm ("magic stuff accessing an 'int' pointed to by '%1'"
>>>>>>> "=&d" (r) : "a" (y), "m" (*y));
>>>>>>> return result;
>>>>>>> The example looks like it describes the in_cksum_hdr() problem.
>>>>>>> I made the following change:
>>>>>>> diff -u -r1.5 in_cksum.h
>>>>>>> --- machine/in_cksum.h 2 Sep 2003 21:31:16 -0000 1.5
>>>>>>> +++ machine/in_cksum.h 3 Jul 2006 14:06:25 -0000
>>>>>>> @@ -59,10 +59,11 @@
>>>>>>> register u_int sum = 0;
>>>>>>> #define ADD(n) \
>>>>>>> - __asm__ volatile ("addl " #n "(%2), %0" : "=r" (sum) : "0"
>>>>>>> (sum), "r" (ip))
>>>>>>> + __asm__ volatile ("addl " #n "(%2), %0" : "=r" (sum) : "0"
>>>>>>> (sum), "r" (ip), "m" (*ip))
>>>>>>> #define ADDC(n) \
>>>>>>> - __asm__ volatile ("adcl " #n "(%2), %0" : "=r" (sum) : "0"
>>>>>>> (sum), "r" (ip))
>>>>>>> + __asm__ volatile ("adcl " #n "(%2), %0" : "=r" (sum) : "0"
>>>>>>> #define MOP \
>>>>>>> __asm__ volatile ("adcl $0, %0" : "=r" (sum) : "0"
>>>>>>> (sum))
>>>>>>> To my surprise the compiler emits the same code before and after
>>>>>>> I made the change.
>>>>>> I can't confirm this. Using the construct *does* make the
>>>>>> difference:
>>>>>> Compiling the snippet
>>>>>> void test(int *pi)
>>>>>> *pi = 0;
>>>>>> #ifdef USE_MEMB
>>>>>> asm volatile(""::"m"(*pi));
>>>>>> #endif
>>>>>> *pi = 3;
>>>>>> powerpc-rtems-gcc -O -c test.c; powerpc-rtems-objdump -d test.o
>>>>>> produces:
>>>>>> 0: 38 00 00 03 li r0,3
>>>>>> 4: 90 03 00 00 stw r0,0(r3)
>>>>>> 8: 4e 80 00 20 blr
>>>>>> whereas
>>>>>> powerpc-rtems-gcc -O -c -DUSE_MEMB test.c; powerpc-rtems-objdump
>>>>>> -d test.o
>>>>>> does what we want:
>>>>>> 0: 38 00 00 00 li r0,0
>>>>>> 8: 38 00 00 03 li r0,3
>>>>>> c: 90 03 00 00 stw r0,0(r3)
>>>>>> 10: 4e 80 00 20 blr
>>>>>> I also tested i386-rtems-gcc with the same result. Same applies
>>>>>> to native gcc-3.2.3
>>>>>> I have on my linux box.
>>>>>> What compiler are you using? What target did you check? Note that
>>>>>> PPC people
>>>>>> wont' experience PR1110 (look at the ppc implementation of
>>>>>> in_cksum_hdr(),
>>>>>> the reading of the relevant data is done be interspersed C-code).
>>>>>> If you are testing the modified <in_cksum.h> beware of outdated
>>>>>> versions
>>>>>> that might get picked up...
>>>>>> Cheers
>>>>>> -- T.
>>>>>>> Am I reading the GCC manual wrong? Does making this change fix
>>>>>>> things for you?
>>>>>>> Eric Norum <norume at aps.anl.gov <mailto:norume at aps.anl.gov>>
>>>>>>> Advanced Photon Source
>>>>>>> Argonne National Laboratory
>>>>>>> (630) 252-4793
>> (630) 252-4793
