RTEMS Capture Engine
Paul Whitfield paulw at omnitronics.com.au
Wed Jul 12 00:14:19 UTC 2006
Jiri Gaisler wrote:
> Thanks a lot for this info, with
> #define CONFIGURE_MAXIMUM_USER_EXTENSIONS        4
> it works pefectly on my board at least:
> rtems $ copen 100
> capture engine opened.
> rtems $ task
>   ID       NAME   PRIO   STAT   MODES  EVENTS   WAITID  WAITARG  NOTES
> 0a010002   RMON     1   READY  P:T:nA  NONE
> 0a010003   TA1      1   DELAY  P:T:nA  NONE
> 0a010004   TA2      1   DELAY  P:T:nA  NONE
> 0a010005   TA3      1   DELAY  P:T:nA  NONE
> rtems $
Hi Jiri,
Task is a monitor function that does not require the capture engine.
Try ctlist or ctload ...
Also you need to do either
copen -i 100
or
copen 100
cenable
To get the engine working.
Hope that helps!
The capture engine is very useful, however I have never found any
documentation for it other than reading the source code.
Likewise the "built-in" monitor commands - have I missed something or
is this something that RTEMS lacks?
Regards
Paul
The information in this e-mail is intended for the addressee only.
Unauthorised use, copying, disclosure or distribution by anyone else
is prohibited. Please let us know immediately if you receive this
e-mail in error. Thank you.
