Xilinx IP core drivers for RTEMS- Keith Robertson still around?
Ed Sutter
esutter at lucent.com
Tue Jul 18 16:54:50 UTC 2006
Bob,
I gave you what I have for the ML403/micromonitor stuff right?
If you need help with that, lemme know.
Ed Sutter
Robert S. Grimes wrote:
> Hi Greg,
> Please, less formality - Bob is fine by me!
> Sounds like I'll be following you, I guess! I had originally (as in
> earlier today) thought I'd finish my MicroMonitor work first, but
> perhaps I should move RTEMS up first. It doesn't really matter too much
> for me, and hopefully I'll be able to contribute more - given your
> schedule.
> Do you have the TEMAC working yet? Or are you using one of the "soft"
> IP cores? What serial port core are you using?
> Take care,
> gregory.menke at gsfc.nasa.gov wrote:
>> Thanks Robert!
>> Exactly what I needed. Over the next few days I will be working the
>> patches in and comparing to the firmware as its been specified in our
>> board- its quite similar to an ML403. We do have flexibility wrt the
>> Virtex firmware so reconfigs there will not be an issue. I think the
>> goal will be to create a proper bsp to support our board. The initial
>> tests will be RTEMS running our flight software, taking data in over a
>> serial port and transmitting out of ethernet.
>> I'd be happy to share the RTEMS portions of the work & collaborate
>> wherever its feasable. We have to be running & stable by the end of
>> August so development is going to be brisk over the next couple weeks.
>> Regards,
>> Greg
>> Robert S. Grimes writes:
>> > Hi Greg,
>> > > I'm in the same boat as you. Keith has sent me his diffs, which
>> I > include here. Note that they are against a little older version
>> > (V4.6.5) of RTEMS, and should work on a suitably configured Xilinx
>> ml403 > board. You'll have to make sure your V4 configuration is
>> compatible > with his stuff, or change one side or another...
