Problems connecting two embedded boards running RTEMS
A.Jallad at surrey.ac.uk
Thu Jul 27 21:01:51 UTC 2006
It is a timeout failure,
Regards,
Abdul
-----Original Message-----
From: Camilo Alejandro Arboleda [mailto:mislistas.correo at gmail.com]
Sent: 27 July 2006 20:51
To: Jallad AHM Mr (PG/R - Surrey Space Centre)
Cc: rtems-users at rtems.com
Subject: Re: Problems connecting two embedded boards running RTEMS
2006/7/27, A.Jallad at surrey.ac.uk <A.Jallad at surrey.ac.uk>:
> Hi,
> I am trying to make a simple ethernet connection between two embedded boards with a LEON processor running on each. I am trying to make a connection between the two boards running RTEMS. The server starts listening but the client fails to connect.
How does it fail? timeout? connection refused?
> What irritates me most is that the connection works fine between a Linux machine and each of the two boards individually in any configuration (linux machine serving as server and RTEMS board as client and vice-versa).
Algo mas sobre Camilo Alejandro?
http://camiloaa.blogspot.com
