rtems_clock_set @ sparc v7 does not work!
Grigori Khmyrov
grigori_khmyrov at uml.edu
Thu Jun 1 13:56:28 UTC 2006
I can compile my project in 4.6.2 SPARC BSP and use MKPROM to get image,
but the binary I create doesn't boot.
I think one parameter missing in the new MKPROM "-Ttext 0x1000000" to
prepare
image for EEPROM.
Thanks for comments,
Grigori
Joel Sherrill wrote:
> Grigori Khmyrov wrote:
>> Yes, it would be reasonable explanation!
>> I use RTEMS 4.0.0 for the sparc BSP
>> And 4.6.2 for i386 BSP (which works)
>> How can I patch "memory barrier" for version 4.0.0?
>> I can not switch easy to the new rtems version because of mkprom
>> support.
> If you are using 4.0.0 and having problems, then I really can't begin to
> evaluate what is wrong. That is a very very old version and the gcc you
> are using is very likely too old to even trip the memory barrier problem.
> Why is mkprom an issue? There has to be a way to do the equivalent
> functionality after a tool upgrade. Even if you have to use objcopy and
> then run the old mkprom.
> --joel
>> Thank you,
>> Grigori
>>>> When I set new time at sparc v7 board using rtems_clock_set(
>>>> &newTime ) function,
>>>> at some point ticks jump back to previous value!?
>>>> It does not happen if I use rtems_clock_set twice:
>>>> rtems_clock_set
>>>> rtems_clock_set
>>> What version of RTEMS are you using? Does it have the "memory
>>> barrier" patch?
>>> This sounds like the interrupt critical section issue that was
>>> addressed by that patch.
>>>> I have same code running at i386 processor and rtems_clock_set is
>>>> working OK.
>>>> Any ideas?
>>>> Thank you,
>>>> Grigori
