rtems_clock_set @ sparc v7 does not work!
Thu Jun 1 14:01:17 UTC 2006
Can any ERC32 users help here?    Someone has to have faced this before.
--joel
Grigori Khmyrov wrote:
> I can compile my project in 4.6.2 SPARC BSP and use MKPROM to get image,
> but the binary I create doesn't boot.
> I think one parameter missing in the new MKPROM "-Ttext 0x1000000" to
> prepare
> image for EEPROM.
> Thanks for comments,
> Grigori
>>> Yes, it would be reasonable explanation!
>>> I use RTEMS 4.0.0 for the sparc BSP
>>> And 4.6.2 for i386 BSP (which works)
>>> How can I patch "memory barrier" for version 4.0.0?
>>> I can not switch easy to the new rtems version because of mkprom
>>> support.
>> If you are using 4.0.0 and having problems, then I really can't begin to
>> evaluate what is wrong.  That is a very very old version and the gcc you
>> are using is very likely too old to even trip the memory barrier
>> problem.
>> Why is mkprom an issue?  There has to be a way to do the equivalent
>> functionality after a tool upgrade.  Even if you have to use objcopy and
>> then run the old mkprom.
>> --joel
>>> Thank you,
>>> Grigori
>>>>> When I set new time at sparc v7 board using rtems_clock_set(
>>>>> &newTime ) function,
>>>>> at some point ticks jump back to previous value!?
>>>>> It does not happen if I use rtems_clock_set twice:
>>>>> rtems_clock_set
>>>>> rtems_clock_set
>>>> What version of RTEMS are you using?  Does it have the "memory
>>>> barrier" patch?
>>>> This sounds like the interrupt critical section issue that was
>>>> addressed by that patch.
>>>>> I have same code running at i386 processor and rtems_clock_set is
>>>>> working OK.
>>>>> Any ideas?
>>>>> Thank you,
>>>>> Grigori
