ARM Interrups
Camilo Alejandro Arboleda mislistas.correo at gmail.com
Fri Jun 2 15:09:50 UTC 2006
Hello,
May be this question is off-topic (i'm not sure it is an RTEMS
problem). I'm working with the AT91RM9200 processor. I'm trying to
create a DMA based driver for the UARTS, using the peripheral DMA
controller (PDC), but i'm having trouble using it.
I installed the IRQ handler using BSP_install_rtems_irq_handler, and
it cleans current interrupt reading the AIC_IVR (interrupt vector
register), but it only interrupts once. Is there any proper way to
clean up the interrupt in this architecture?
Thanks in advance,
Algo mas sobre Camilo Alejandro?
http://camiloaa.blogspot.com
