4.6.99.3 build failure
Ralf Corsepius ralf.corsepius at rtems.org
Tue Jun 20 14:09:59 UTC 2006
On Tue, 2006-06-20 at 09:36 -0400, Jerry Needell wrote:
> I am trying to build the sparc (leon2 and leon3 ) bsps from the CVS head
> and I get the error below. I obtained the tree via CVS then ran
> .bootstrap and tried to build.
> syscall.o was created, but it was in the ..../libcpu/sparc subdirectory,
> not in  .....libcpu/sparc/syscall as the Makefile seems to expect.
> any suggestions about the cause?
Probably using vanilla automake, instead of using the rtems-patched automake.
Are you building from CVS or from the tarball? If the latter applies,
the tarball probably is broken.
Ralf
