4.6.99.3 build failure
Tue Jun 20 15:33:26 UTC 2006
Jerry Needell wrote:
> Joel - where can I find the rpm for the rtems patched automake-1.9.6?
> Do you know what patches were applied to create it?
http://www.rtems.com/ftp/pub/rtems/linux/redhat/7.3/i386/rpms/rtems-4.7/rtems-4.7-automake-rtems-1.9.6-0/
There is an RPMS, SRPMS, and SOURCES directory under there.
Other RPMs are one directory up at:
This is a list of the SPARC specific and autotools RPMs I have
installed.  I have not done
enough testing on the gcc 4.1.1 RPMs to feel comfortable about putting
them on the ftp site
but I am close to that point.
bash-3.00$ rpm -qg RTEMS/4.7 | grep sparc
rtems-4.7-sparc-rtems4.7-binutils-2.16.1-3
rtems-4.7-sparc-rtems4.7-libc-1.14.0-2
rtems-4.7-sparc-rtems4.7-gdb-6.4-4
rtems-4.7-sparc-rtems4.7-gcc-4.1.1-2
rtems-4.7-sparc-rtems4.7-c++-4.1.1-2
bash-3.00$ rpm -qg RTEMS/4.7 | grep  auto
rtems-4.7-autoconf-rtems-2.59-4
> I am trying to build from  CVS. I'll give the tarball a try later
> today to see if that makes a difference.
> - Jerry
> On Jun 20, 2006, at 10:57 AM, Joel Sherrill wrote:
>> Ralf Corsepius wrote:
>>> On Tue, 2006-06-20 at 09:36 -0400, Jerry Needell wrote:
>>>> I am trying to build the sparc (leon2 and leon3 ) bsps from the
>>>> CVS head and I get the error below. I obtained the tree via CVS
>>>> then ran .bootstrap and tried to build.
>>>> syscall.o was created, but it was in the ..../libcpu/sparc
>>>> subdirectory, not in  .....libcpu/sparc/syscall as the Makefile
>>>> seems to expect.
>>>> any suggestions about the cause?
>>> Probably using vanilla automake, instead of using the rtems- patched
>>> automake.
>>> Are you building from CVS or from the tarball? If the latter applies,
>>> the tarball probably is broken.
>> I assume CVS head since his first line said that.  The automake
>> looks like the culprit.
>> I have no outstanding changes in my source tree and those built
>> yesterday afternoon
>> local time.
>>> Ralf
