4.6.99.3 build failure
Jerry Needell jerry.needell at unh.edu
Tue Jun 20 15:47:42 UTC 2006
thanks Joel - I get lost in the trees!
BTW - I was able to build the CVS tree after applying the 1.9.5 patches
to automake-1.9.6 - the key was to do a ./bootstrap before rebuilding!
onward!
thanks for all the help.
- Jerry
Joel Sherrill wrote:
> Jerry Needell wrote:
>> Joel - where can I find the rpm for the rtems patched
>> automake-1.9.6?  Do you know what patches were applied to create it?
> http://www.rtems.com/ftp/pub/rtems/linux/redhat/7.3/i386/rpms/rtems-4.7/rtems-4.7-automake-rtems-1.9.6-0/
> There is an RPMS, SRPMS, and SOURCES directory under there.
> Other RPMs are one directory up at:
> This is a list of the SPARC specific and autotools RPMs I have
> installed.  I have not done
> enough testing on the gcc 4.1.1 RPMs to feel comfortable about putting
> them on the ftp site
> but I am close to that point.
> bash-3.00$ rpm -qg RTEMS/4.7 | grep sparc
> rtems-4.7-sparc-rtems4.7-binutils-2.16.1-3
> rtems-4.7-sparc-rtems4.7-libc-1.14.0-2
> rtems-4.7-sparc-rtems4.7-gdb-6.4-4
> rtems-4.7-sparc-rtems4.7-gcc-4.1.1-2
> rtems-4.7-sparc-rtems4.7-c++-4.1.1-2
> bash-3.00$ rpm -qg RTEMS/4.7 | grep  auto
> rtems-4.7-autoconf-rtems-2.59-4
>> I am trying to build from  CVS. I'll give the tarball a try later
>> today to see if that makes a difference.
>> - Jerry
>> On Jun 20, 2006, at 10:57 AM, Joel Sherrill wrote:
>>> Ralf Corsepius wrote:
>>>> On Tue, 2006-06-20 at 09:36 -0400, Jerry Needell wrote:
>>>>> I am trying to build the sparc (leon2 and leon3 ) bsps from the
>>>>> CVS head and I get the error below. I obtained the tree via CVS
>>>>> then ran .bootstrap and tried to build.
>>>>> syscall.o was created, but it was in the ..../libcpu/sparc
>>>>> subdirectory, not in  .....libcpu/sparc/syscall as the Makefile
>>>>> seems to expect.
>>>>> any suggestions about the cause?
>>>> Probably using vanilla automake, instead of using the rtems-
>>>> patched automake.
>>>> Are you building from CVS or from the tarball? If the latter applies,
>>>> the tarball probably is broken.
>>> I assume CVS head since his first line said that.  The automake
>>> looks like the culprit.
>>> I have no outstanding changes in my source tree and those built
>>> yesterday afternoon
>>> local time.
>>>> Ralf
