serious termios flaw?
Till Straumann strauman at slac.stanford.edu
Sun Jun 25 19:19:24 UTC 2006
Thomas.
Thanks for clarifying.
Where I seem to have problems is 'ppp_tty.c:pppstart,
lines 637-648'.
I can't see how characters dropped by the 'write' routine
are saved and written later.
Till
Thomas Doerfler wrote:
>-----BEGIN PGP SIGNED MESSAGE-----
>Hash: SHA1
>Till,
>I am not sure which mode of termios drivers you are referring to.
>Generally the termios driver API can pass multiple characters to a write
>routine. in polled mode, the driver's polled write function must send
>all given characters to the hardware. I can see this implemented e.g. in
>the "pc386" BSP in console.c:
>static int
>ibmpc_console_write(int minor, const char *buf, int len)
>  int count;
>  for (count = 0; count < len; count++)
>    _IBMPC_outch( buf[ count ] );
>    if( buf[ count ] == '\n')
>      _IBMPC_outch( '\r' );            /* LF = LF + CR */
>  return 0;
>In interrput mode, termios can pass a rather long buffer to the driver's
>write function, but the driver is not forced to handle that size.
>Instead, when the driver's interrupt function calls
>"rtems_termios_dequeue_characters", it passes to termios how many
>characters have been sent out to the device. Simple devices without FIFO
>or DMA support may always pass a "1" to this function, then termios will
>pass the rest of the send buffer once more to the device driver's write
>function.
>wkr,
>Thomas.
>Till Straumann schrieb:
>>I found that termios (and, BTW: ppp_tty) call
>>the low-level driver's 'write' routine, possibly supplying
>>more than one character and without checking
>>the return code of 'write'.
>>Most UART drivers OTOH (I checked i386, ppc, uC5282[coldfire]),
>>silently discard anything after the first char in the buffer.
>>This is not reflected in the return code.
>>IMO, the low-level drivers should return the # of chars
>>actually written and the upper layers should check for and
>>handle this case.
>>Am I missing something?
>>Till
>IMD Ingenieurbuero fuer Microcomputertechnik
>Thomas Doerfler           Herbststrasse 8
>D-82178 Puchheim          Germany
>email:    Thomas.Doerfler at imd-systems.de
>PGP public key available at:
>     http://www.imd-systems.de/pgpkey_en.html
>-----BEGIN PGP SIGNATURE-----
>Version: GnuPG v1.4.3 (MingW32)
>Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
>iD8DBQFEnlSqwHyg4bDtfjQRAgA8AJ9/QLrB4jL5CwglhCZATZ9JTaeQJgCfRYsN
>pI4KKdv+/L8xSH1H8XkSXqU=
>=YRSP
>-----END PGP SIGNATURE-----
