SPARC V9 support
jonathan.kalbfeld at gmail.com
Thu Jun 1 17:46:18 UTC 2006
I was going to try the same thing but on an old one. I have a stack
of Sparc 1+'es in my garage and I was curious if anyone had tried this
on a sparcv8 machine?
If you're in the LA area and want a free sparc 1+ to try this out, let
me know :-)
jonathan
On 6/1/06, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> Alexandre Constantino wrote:
> >Hi,
> >I tried to run the hello_world executive on a SPARC V9 (Ultra 5) machine
> >using SILO but the result wasn't very encouraging.
> >Using the ERC32 and ERC32nfp OpenBoot error messaged me with "Fast
> >Instruction Access MMU Miss"
> >With the Leon1 BSP I received an "Illegal Instruction" error message.
> >Digging into RTEMS mail archives I found one single message (with no
> >replies) about the V9:
> >http://www.rtems.com/ml/rtems-users/2002/november/msg00216.html
> >And indeed the V9 has undergone a lot of changes, like the PSR
> >(Processor State Register) being deleted... And RTEMS can't work without
> >this one :)
> >http://docs.sun.com/app/docs/doc/806-3774
> >OTOH Wikipedia states that "The architecture has provided continuous
> >application binary compatibility from the first SPARC V7 implementation
> >in 1987 into the Sun UltraSPARC Architecture implementations."
> >http://en.wikipedia.org/wiki/UltraSparc
> >And on RTEMS webpage it is mentioned that RTEMS supports "SPARC V7 and
> >above CPUs"
> >http://www.rtems.com/targets.html
> >Could anyone clarify me on this?
> Sounds like we trusted Sun on what they said. :)
> I don't know of anyone who has ever successfully run RTEMS on any SPARC
> other than
> an ERC32 or LEON. Those were/are the most popular embedded SPARC
> CPUs. According
> to the documentation, it should have worked on more advanced CPU models.
> Looking at the changes section and making an educated guess, I would say
> that score/cpu/sparc
> is going to need some v7/v8/v9 ifdef's for the PSR and that the
> windowing trap handler is
> going to need to be different. The size of the registers in the context
> data structure will have to
> be conditional for 32/64 bits.
> It should have no impact outside cpukit/score/cpu/sparc, libcpu/sparc,
> and you will have to have a
> new BSP for the Ultra. But given their documentation on differences, it
> should be fairly mechanical
> to review the SPARC specific code in RTEMS and identify the areas.
> Looks like a handful of point
> modifications ignoring the BSP issue.
> >Thank you for your time.
Jonathan Kalbfeld
+1 323 620 6682
