bits swap within a byte
Thu Jun 8 17:25:08 UTC 2006
Kate Feng wrote:
> Is there any elegant built-in macro which does bits swap
> within each byte or other alternatives ?  For example,
> bit 0 <-> bit 7, bit 1 <->bit 6, bit 2 <->bit 5, bit3 <->bit 4 ?
I would this link on Google with multiple algorithms:
http://graphics.stanford.edu/~seander/bithacks.html
And at
http://www.ocf.berkeley.edu/~wwu/cgi-bin/yabb/YaBB.cgi?board=riddles_cs;action=display;num=1103355188
I found this code snippet which looks promising.
n = n&11110000 >>4 | n&00001111 << 4;
n = n&11001100 >>2 | n&00110011 << 2;
return  n&10101010 >>1 | n&01010101 << 1;
I am not sure the bit constants are specified correctly though.  Looks
like some would be turned to octal and others
to decimal to me.  Better to convert them to hex and be sure.  Might as
well as parentheses as well.
It can be faster to do a table lookup.   Rather than a 256 entry table,
tt should be possible to work on nibbles and
then use a 16 entry table to swap the nibble values.
--joel
> Thanks,
> Kate
