Powerpc 4.7 build
jennifer at oarcorp.com
Thu Jun 22 19:56:49 UTC 2006
The tools are now installed under the directory rtems4.7. This allows
multiple versions of rtems to be used on the same machine.
The target should be powerpc-rtems4.7 instead of powerpc-rtems.
Hope this helps
Jennifer
> Why are the binaries in the tools RPM called powerpc-rtems4.7-gcc rather
> than the standard powerpc-rtems-gcc?
> What do I need to pass into configure so that it can find these
> executables.
> Thx - Greg
