Motorola roadmap
Till Straumann strauman at slac.stanford.edu
Fri Jun 23 16:57:06 UTC 2006
Eric Norum wrote:
> The Motorola roadmap shows long term support for only the MVME3100
currently no plans to use 3100
>   and the MVME6100.
Done. We're using 6100s for the LCLS project. I have a pretty complete
BSP that has been under test for almost a year now. It is binary compatible
with the 5500, too (i.e., you can use the same BSP and run applications
on either board [run-time detection]).
The BSP is called 'beatnik' in commemoration of the fifties/sixties epoch...
-- Till
>   Is anyone in RTEMS-land working on BSPs for these  cards?
