creating patch for CVS tree
Karel Gardas
kgardas at objectsecurity.com
Wed Jun 28 14:07:20 UTC 2006
Thanks to CVS limitations you will probably need to checkout second tree,
keep both trees updated and then do recursive diff between them.
Personaly I find this too much horrible and so I use darcs
(http://www.darcs.net) to get the diff. i.e. in updated CVS do:
darcs init
darcs add -r *
darcs rec -a
<type `Initial import' and then enter>
and now just do all your changes and add files by using `darcs add <file>'
and once done just do:
darcs diff -u
Cheers,
Karel
On Wed, 28 Jun 2006, Jerry Needell wrote:
> I'll admit to being confused ans a novice with CVS. I downloaded the 4.6.99.3
> tree via CVS and have made some changes. The changes were to a few existing
> files and I have added some new files in existing subdirectories and added a
> new subdirectory. The code builds and tests so now I am trying to generate a
> patch for submission. How do I generate the patch? So far my attempts have
> genrated diff files that include only chages to the pre-existing files, but
> do not include the new files or subdirectory. Can someone give an example of
> the proper way to generate the patch?
> - thanks - Jerry
Karel Gardas kgardas at objectsecurity.com
ObjectSecurity Ltd. http://www.objectsecurity.com
