Problem when compiling gcc for rtems-4.6 toolchain
Dominik Brader dbrader at gmx.net
Thu Mar 2 20:10:59 UTC 2006
Hello Angelo,
thank you for your reply...
I tried your suggestions but it still didn't work.
The error is still the same...
Dominik
On Wednesday 01 March 2006 00:57, Angelo Fraietta wrote:
> Dominik Brader wrote:
> > On Tuesday 28 February 2006 21:59, you wrote:
> >>Dominik Brader wrote on 2/28/06 12:45 PM:
> >>>Hello,
> >>>I have a problem when compiling the gcc for the RTEMS-4.6. toolchain.
> >>>I am using binutils-2.13.2.1, gcc-3.2.3 with
> >>>gcc-3.2.3-rtems-20040420.diff patch and newlib-1.11.0 with
> >>>newlib-1.11.0-rtems-20030605.diff patch.
> I had a very similar problem the other day.
> I found that I had to use gcc 3.3.5 to make it work for rtems 4.6.4
> I have the whole procedure at
> http://www.smartcontroller.com.au/~angelo/rtems/RTEMSForSmartController.htm
>l
> Let me know if it helps
Dominik Brader - Friedenheimerstr. 16 - 80687 München
