Problem when compiling gcc for rtems-4.6 toolchain
Thu Mar 2 20:26:31 UTC 2006
Dominik Brader wrote:
>Hello Angelo,
>thank you for your reply...
>I tried your suggestions but it still didn't work.
>The error is still the same...
Did you install the old native gcc and put it at the front of your PATH?
echo $PATH
gcc --version
and make sure.
--joel
>Dominik
>>>On Tuesday 28 February 2006 21:59, you wrote:
>>>>Dominik Brader wrote on 2/28/06 12:45 PM:
>>>>>Hello,
>>>>>I have a problem when compiling the gcc for the RTEMS-4.6. toolchain.
>>>>>I am using binutils-2.13.2.1, gcc-3.2.3 with
>>>>>gcc-3.2.3-rtems-20040420.diff patch and newlib-1.11.0 with
>>>>>newlib-1.11.0-rtems-20030605.diff patch.
>>I had a very similar problem the other day.
>>I found that I had to use gcc 3.3.5 to make it work for rtems 4.6.4
>>I have the whole procedure at
>>http://www.smartcontroller.com.au/~angelo/rtems/RTEMSForSmartController.htm
>>l
>>Let me know if it helps
