Problem to save file on the hard disk! What I have to set to do it ?
    Thomas Doerfler (nt)
    Thomas.Doerfler at imd-systems.de
    Tue Mar 14 07:15:05 UTC 2006
Matteo,
it really looks like a difficult case to me :-((
What is confusing me: Your FAT partition has a size of about 20GB. This
is MUCH to big for a FAT16 partition, so I would guess, that a program
that is asked to format the disk should complain about this.
In your last posts, you have sent me information about what is written
in the partition table for partition hda1. For clarity, I have to ask
again: did you also:
- format the partition
- mount it under linux to some mount point
- write files to it
and everything without problems?
wkr,
Thomas.
Matteo schrieb:
> Thomas,
> Yes I can access to windows from linux.
> I created hda1 using gparted formatting hda1 as FAT16.
> Infact if I use gparted, like you can see, it says that is FAT16, but if I use
> only "cfdisk" says that is only linux.
> I try to see my memory using also qtparted and It says me that hda1 is FAT16
> partition.
> I don't know why "cfdisk -l /dev/hda" don't shows that hda1 is FAT16.
> But both gparted both qtparted program shows that hda1 is a FAT16 !
> Have you some idea about my problem ?
> Really Thanks in advance
> Matteo
> Scrive "Thomas Doerfler (nt)" <Thomas.Doerfler at imd-systems.de>:
> Matteo,
> I am a bit confused, your listing shows, that /dev/hda1 is a Linux ext3
> partition, but you write that gparted shows it as FAT16. But /dev/hda2
> looks fine in the partition table. can you access the filesystem on
> /dev/hda2 from linux?
> Thomas.
> Matteo schrieb:
>>Ok this is the result of the command "fdisk -l /dev/hda"
>>Disk /dev/hda: 40.0 GB, 40007761920 bytes
>>255 heads, 63 sectors/track, 4864 cylinders
>>Units = cilindri of 16065 * 512 = 8225280 bytes
>>Dispositivo Boot      Start         End      Blocks   Id  System
>>/dev/hda1            2678        3014     2706952+  83  Linux
>>/dev/hda2               1        2677    21502971    c  W95 FAT32 (LBA)
>>/dev/hda3            3015        4784    14217525   83  Linux
>>/dev/hda4            4785        4864      642600    5  Esteso
>>/dev/hda5            4785        4864      642568+  82  Linux swap /
> Solaris
>>looking with gparted I have the result that, hda1 is "FAT16", hda2 is
> "FAT32",
>>hda3 is "ext3", hda4 is "exetended", hda5 is "linux swap".
>>I created hda1 with FAT16 thinking to resolve the problem, but from the
> fileio
>>example I have always the same error,
>>" fsmount: mounting of "/dev/hda1" to "/mnt/hda1" failed: No such file or
>>directory " but now hda1 is FAT16 so it could be right for RTEMS, but it
> isn't.
>>Why ?
>>Can you help me ?
>>Thanks advanced
>>MAtteo
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at:
     http://www.imd-systems.de/pgpkey_en.html
