Problem to save file on the hard disk! What I have to set to do it ?
Matteo matteo.posterli at studenti.unipr.it
Fri Mar 17 10:42:21 UTC 2006
Hi Chris,
I download another time the fileio example from the ;
http://www.rtems.org/cgi-bin/viewcvs.cgi/rtems/testsuites/samples/fileio/
I try to run it but it doens't works, so I try to add to the system.h ;
#define CONFIGURE_INIT_TASK_STACK_SIZE  (100 * RTEMS_MINIMUM_STACK_SIZE)
but I have the same problem, it doesn't run.
I have installed; rtems-4.6.99.2, gcc-4.0.2, newlib-1.13.0, on i386.
So why doesn't run the fileio example ?
Scrive Chris Johns <chrisj at rtems.org>:
> Angelo Fraietta wrote:
> > Could you please send me a link to the latest fileio example. I have
> > been using the dos driver for a while with no problem. I can test it
> > here on a machine
> Under CVS you can file the sample program here:
> Regards
> Chris
