Problem to save file on the hard disk! What I have to set to do it ?
Ian Caddy ianc at goanna.iinet.net.au
Mon Mar 20 13:59:41 UTC 2006
Joel Sherrill wrote:
> Matteo wrote:
>> Hi Joel,
>> following your suggestion I follow the
>> http://www.rtems.com/wiki/index.php/RTEMSAda guide, but I have a problem.
>> I download from the cvs rtems and I have only this in the directory;
>> acinclude.m4 aclocal automake bootstrap bpskit c
>> So, like the guide suggests, I launch ./bootstrap but I have this
>> error  ;
>> bash: ./bootstrap. /bin/sh^M: bad interpreter: no such file or directory
> This looks like something happened with CR/LF on the CVS checkout.   My
> guess would
> be that you are on Cygwin and somehow using a partition with automatic
> CR/LF.
The other reason for this is that if you extract a tar.gz file using
Winzip (or other windows extraction programs) into the Cygwin
environment, it will *not* extract properly.
You need to use the tar command in the cygwin shell to extract any file
archives.
I hope this helps.
Ian Caddy
Goanna Technologies Pty Ltd.
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.385 / Virus Database: 268.2.5/284 - Release Date: 17/03/2006
