Filio example doesn't run with rtems from the cvs
Thomas Doerfler (nt) Thomas.Doerfler at imd-systems.de
Mon Mar 20 19:22:49 UTC 2006
matteo,
have a look at
rtems/make/Templates/Makefile.leaf
Thomas.
Matteo schrieb:
> Hi Thomas,
> the link is at the same file system.h that I use in the samples fileio that I
> try to run, so I think, isn't that the problem.
> May be, like you say, I have to adjust my make file but How I can add "the
> semaphore and message queue managers"?
> Thanks in advance
> MAtteo
> Scrive Thomas Doerfler <Thomas.Doerfler at imd-systems.de>:
>>Matteo,
>>have a look at:
> http://www.rtems.com/cgi-bin/viewcvs.cgi/~checkout~/rtems/testsuites/samples/fileio/system.h?rev=1.6&content-type=text/plain
>>you can see the proper things required in system.h, it is important,
>>that the IDE and the ATA drivers are included (and the IDE driver is
>>included before the ATA driver). You will also need the bdbuf
>>configuration. I have seen in your makefile, that you do not include the
>>semaphore and message queue managers. This might also cause problems,
>>because the drivers will need message queues and semaphores.
>>Thomas.
>>Matteo wrote:
>>>Hi Thomas,
>>>the makefile is ;
>>>#  Makefile
>>>#  RTEMS_MAKEFILE_PATH is typically set in an environment variable
>>>EXEC=fileio.exe
>>>PGM=${ARCH}/$(EXEC)
>>># optional managers required
>>>MANAGERS=io
>>># C source names
>>>CSRCS = init.c
>>>COBJS_ = $(CSRCS:.c=.o)
>>>COBJS = $(COBJS_:%=${ARCH}/%)
>>># C++ source names
>>>CXXSRCS =
>>>CXXOBJS_ = $(CXXSRCS:.cc=.o)
>>>CXXOBJS = $(CXXOBJS_:%=${ARCH}/%)
>>># AS source names
>>>ASSRCS =
>>>ASOBJS_ = $(ASSRCS:.s=.o)
>>>ASOBJS = $(ASOBJS_:%=${ARCH}/%)
>>># Libraries
>>>LIBS = -lrtemsall -lc
>>>include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
>>>include $(RTEMS_CUSTOM)
>>>include $(PROJECT_ROOT)/make/leaf.cfg
>>>OBJS= $(COBJS) $(CXXOBJS) $(ASOBJS)
>>>all:    ${ARCH} $(PGM)
>>>$(PGM): $(OBJS)
>>>	$(make-exe)
>>>j:
>>>	@echo $(CFLAGS_DEBUG_V)
>>>	@echo $(RTEMS_USE_GCC272)
>>>in init.c is included the system.h.
>>>But I don't see "RTEMS_BSP_HAS_IDE_DRIVER", where and how should I use it
>>>To put like a "#define RTEMS_BSP_HAS_IDE_DRIVER" in system.h or to put it
>>>someway in the makefile ?
>>>Thanks in advance
>>>Matteo
>>>>Matteo,
>>>>what where your exact steps, when your compiled fileio separately? Which
>>>>makefile did you use, did you also copy the "system.h" file? There is a
>>>>BSP preprocessor define which is vital for "fileio", it is called
>>>>"RTEMS_BSP_HAS_IDE_DRIVER".
>>>>wkr,
>>>>Thomas.
>>>>Matteo wrote:
>>>>>Ok , I see from ftp://ftp.rtems.com/pub/rtems/4.6.99.2/TOOL_VERSIONS that
>>>>I'm
>>>>>using a compatible version of gcc, newlib and binutils (gcc-4.0,
>>>>newlib-1.13,
>>>>>binutils-2.16).
>>>>>Infact using this toolset I can compile correctly rtems and the testsuite
>>>>and
>>>>>fileio example works well.
>>>>>After I take the source code of fileio example and I compiled it and the
>>>>example
>>>>>doesn't works!
>>>>>How it's possible, I use the same source file, the only difference is
>>that
>>>>in
>>>>>the first case the example are compiled automatically with rtems and in
>>>>the
>>>>>second case I compiled the source code of the example separately.
>>>>>Note that I try compile separately the hello and ticker examples  and
>>they
>>>>works
>>>>>well, so why fileio doesn't work ?
>>>>>Thank in advance
>>>>>Matteo
>>>>IMD Ingenieurbuero fuer Microcomputertechnik
>>>>Thomas Doerfler           Herbststrasse 8
>>>>D-82178 Puchheim          Germany
>>>>email:    Thomas.Doerfler at imd-systems.de
>>>>PGP public key available at:
>>>>     http://www.imd-systems.de/pgpkey_en.html
